Xusen Posted January 17, 2008 Posted January 17, 2008 Hi I am trying to watch tv using a usb tuner with intel ce9500, i scanned for channels and it found all the important ones, the signal is near perfect as its a residential flat tv connection, but when i select a channel it freezes and does nothing, no picture on screen and no EPG data. I have previously used another card and it worked perfectly. Any help you can provide will be appreciated. * Intel CE9500 and Driver Version 2.0.0.0 * Intel P965 on asus P5B Deluxe * ATi Radeon X1950 - Driver Version 8.411.0.0 Thanks support.zip Quote
Moses Posted January 17, 2008 Posted January 17, 2008 There are two things: - go to options->Hardware and set the unicast network device to "Do not use". It can happen that the wizard enables it, this is a bug inside the wizard, and is very likely your problem. - go to options->directX and change the decoders from "System Default" to your favorite decoder, I'd suggest ffdshow from the ones on your system... maybe you should think about installing PowerDVD or another DVD Player Software to get more decent decoders and select them in DVBViewer. If you had no trouble with ffdshow, then it's ok Quote
Xusen Posted January 18, 2008 Author Posted January 18, 2008 There are two things:- go to options->Hardware and set the unicast network device to "Do not use". It can happen that the wizard enables it, this is a bug inside the wizard, and is very likely your problem. - go to options->directX and change the decoders from "System Default" to your favorite decoder, I'd suggest ffdshow from the ones on your system... maybe you should think about installing PowerDVD or another DVD Player Software to get more decent decoders and select them in DVBViewer. If you had no trouble with ffdshow, then it's ok Thanks A LOT for the reply, I followed your suggestions and I have got it working !!, it might also have been the drivers I reinstalled, the device is now shown as "CE6230 BDA". Thanks again and have a nice weekend. Quote
wiak Posted January 19, 2008 Posted January 19, 2008 Thanks A LOT for the reply, I followed your suggestions and I have got it working !!, it might also have been the drivers I reinstalled, the device is now shown as "CE6230 BDA". Thanks again and have a nice weekend. hi, how did you get that there? i have a CE9500 to, atleast it what vista says it is Quote
Xusen Posted January 20, 2008 Author Posted January 20, 2008 Hi Sorry i am not using vista, i am using xp, i used the drivers that came with the card on cd ..i have attached copy for u to try. Good luck Drivers.zip Quote
wiak Posted January 21, 2008 Posted January 21, 2008 Hi Sorry i am not using vista, i am using xp, i used the drivers that came with the card on cd ..i have attached copy for u to try. Good luck do you get corrupt frames sometimes? like this Quote
Xusen Posted February 2, 2008 Author Posted February 2, 2008 Hey Sorry for the late reply, but no , i am not getting corrupt frames. i have a bigger problem though, as soon as i launch DVBViewer and select a channel the whole application freezes (i cant seem to close it aswell.) and this happens to the card in device manager. "This device is not working properly because Windows cannot load the drivers required for this device. (Code 31)" I have to remove the device and reinstall driver and reboot to make it work again..even then it only works once in a while. any suggestions? Thanks Quote
TomyN Posted November 25, 2008 Posted November 25, 2008 - go to options->Hardware and set the unicast network device to "Do not use". - go to options->directX Hi, I'm wondering where those settings are located. I'm using XP SP3 with german language, and fail to find those settings. Tomy Quote
RemnantAUS Posted April 7, 2010 Posted April 7, 2010 (edited) Intel CE9500 DVB-T (Enh) Receiver is what it says in my Device Manager on my Windows Vista 64bit. But it says "failed to load this device" and cannot use the USB TV dongle on my Vista. But it works perfectly on all my Windows XP SP3 computers though. Anyone know a solution to get the device to work on Vista? Has anyone ever got it working on Vista yet? This is the message I get: Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39) Cheers from Australia Edited April 7, 2010 by RemnantAUS Quote
tweiske Posted July 30, 2010 Posted July 30, 2010 The drivers in this thread are for 32bit only for CE9500. It will not install on 64bit Win 7 or Vista. I couldn't find a 64bit driver. Anyone else? Quote
