Sound problem in 3.9.2.0
avoidz
Hi, after updating to version 3.9.2.0 the TV sound keeps going off when the channel is changes or even randomly (DVBViewer crashed on one occasion).
I can get the sound back by going into Options and enabling a different Audio Renderer under the DirectX level, but then it'll disappear again shortly afterward.
I've gone back to version 3.9.1.0 which works just fine. Not sure what has changed in the latest version to cause this <_<
In any case, thanks for the best DVT player for my PC ;)
try installing the dvbsource filter 3.0.1 from the membersarea, there was a bug in it. normally the current setup from the membersarea does contain the fix.
Thank you, Lars ;)
