girder3 plugin: WindowID faulty
steph99
Hi!
After a very long time I finally found some time to play with DVBV again :)
I use girder 3, Igorplug and the latest girder plugin 1.1.
My Problem:
In girder's variable display the variable reg1 always shows -1 (=no OSD) for the following 2 OSD-windows:
_a) myminiepg and
_;) the osd menu.
--> So I guess in these cases the WindowID isn't transferred to the plugin.
I want to achieve a context sentsitive function of one remote button for back and OSD exit.
So I need to know if ANY OSD window is visible or none.
This should be possible via the variable reg1, but...
Also: is there a way to change the WindowID of OSD windows?
Any help/hint would be appreciated.
Thanks!
Stephan
Hi!
forgot to mention: I use the great OSD skin concinnity 3D.
And I tried other skins including the default skin as well - still no luck.
WindowID/reg1 isn't updated when I open the OSD menu or the myminiepg.
Hi again,
I answer myself >_<
It seems that after closing girder and DVBV, the variables are shown correctly again.
However, sometimes they are not, sometimes they are.
So, it's a bit like "fuzzy logic"... :)
I'll monitor this behaviour and try to find out who's the culprit.
I start to think that maybe it's caused by the Igor plugin or its driver not functioning correctly under vista.
Not sure though.
