andreasimner Posted January 29, 2008 Posted January 29, 2008 I just started using DVBServer as I am setting up an extra client without TV-card. The setup is like this: "HTPC" : Computer running DVBServer that has access to m Hauppauge NOVA-T 500 dual tuner. Also runs DVBViewer that uses the Unicast devices available from the DVBServer. "HTPC2": Computer running DVBViewer that connects to the unicast devices available from DVBServer on computer "HTPC" Everyting works good and I get picture and sound on both computers. Problem: On "HTPC", when I exit DVBViewer (via X-button, via "Exit" in menu etc), the DVBViewer program remains open and responsive but the picture freezes. Instead, the DVBServer icon disapears and DVBServer is shut down. If I attempt to exit DVBViewer again, it is shut down. This problem doesn't happen when I exit DVBViewer on "HTPC2"... The problem also remains if DVBViewer on "HTPC" uses the TV-card directly instead of via DVBServer = Exiting DVBViewer shut downs DVBServer but picture doesnt freeze Any suggested solution? support.zip Quote
andreasimner Posted February 4, 2008 Author Posted February 4, 2008 I just started using DVBServer as I am setting up an extra client without TV-card. The setup is like this:"HTPC" : Computer running DVBServer that has access to m Hauppauge NOVA-T 500 dual tuner. Also runs DVBViewer that uses the Unicast devices available from the DVBServer. "HTPC2": Computer running DVBViewer that connects to the unicast devices available from DVBServer on computer "HTPC" Everyting works good and I get picture and sound on both computers. Problem: On "HTPC", when I exit DVBViewer (via X-button, via "Exit" in menu etc), the DVBViewer program remains open and responsive but the picture freezes. Instead, the DVBServer icon disapears and DVBServer is shut down. If I attempt to exit DVBViewer again, it is shut down. This problem doesn't happen when I exit DVBViewer on "HTPC2"... The problem also remains if DVBViewer on "HTPC" uses the TV-card directly instead of via DVBServer = Exiting DVBViewer shut downs DVBServer but picture doesnt freeze Any suggested solution? 1 week since post.... Quote
naggn Posted February 10, 2008 Posted February 10, 2008 You have to deinstall the recording service. Quote
andreasimner Posted February 11, 2008 Author Posted February 11, 2008 You have to deinstall the recording service. Ok, thanks! I'll try that Quote
andreasimner Posted February 26, 2008 Author Posted February 26, 2008 You have to deinstall the recording service. Didnt work at all. I have no recodring service to deinstall? Maybe one of the official DVBViewer forum moderators can help a paying user? Quote
Lars_MQ Posted February 26, 2008 Posted February 26, 2008 No problem. rename your plugins folder in the DVBViewer program folder to plugins2. Quote
andreasimner Posted February 27, 2008 Author Posted February 27, 2008 No problem. rename your plugins folder in the DVBViewer program folder to plugins2. But now my MCE remote plugin stopped working? Quote
Lars_MQ Posted February 27, 2008 Posted February 27, 2008 Does your main problem go away? If yes, you create a new plugins folder and copy one plugin at a time into it and test it until you found the guilty plugin. Quote
