Marcone Posted February 10, 2008 Posted February 10, 2008 Hello, my DVBViewer latest version with my jeppsen dvb-s board (same hardware as hauppauge nova-s), after some channel zapping hang here the support.zip: support.zip thank you for any assistance you can give Marco Quote
Marcone Posted February 10, 2008 Author Posted February 10, 2008 forget to tell that problem occours without any plugin active and is is not a channel relate problem because occour on different channel cripted and unecnrypted Quote
Marcone Posted February 10, 2008 Author Posted February 10, 2008 attached the deblug log from the crash, latest change channel and dvbdream hang without any error messages Marco debug.log Quote
Lars_MQ Posted February 11, 2008 Posted February 11, 2008 try other audio/video decoders in options -> DirectX. Quote
Marcone Posted February 11, 2008 Author Posted February 11, 2008 (edited) try other audio/video decoders in options -> DirectX. tryed no luck. Tryd also different overlay options. Marco Edited February 11, 2008 by Marcone Quote
Gioxy Posted February 11, 2008 Posted February 11, 2008 Try also to change the renderer and the audio decoder... I can also notice you have a mess of codecs: have you ever installed a CodecPack? IMHO the most stable codec/DirectX combination you can use to investigate further on your prob is: Renderer: Overlay Video: CyberLink Video/SP Decoder Video H.264: CyberLink H.264/AVC Decoder (PDVD7.x) Audio: CyberLink Audio Decoder (PDVD7 UPnP) Detection Audio/Video: No/No NVidia bug: yes Update/reinstall also your DirectX with the very last version (november 2007)... ...and monitor the CPU usage with some tool to see if the crash happen with the CPU at full gear... Quote
Marcone Posted February 12, 2008 Author Posted February 12, 2008 IMHO the most stable codec/DirectX combination you can use to investigate further on your prob is:Renderer: Overlay Video: CyberLink Video/SP Decoder Video H.264: CyberLink H.264/AVC Decoder (PDVD7.x) Audio: CyberLink Audio Decoder (PDVD7 UPnP) Detection Audio/Video: No/No NVidia bug: yes thank you, with this combination of codec an render it works, but video quality is better with ffdshow any way to use it? In any case ia am waiting for a skystar hd so I should try with this sat card. Nvidia bug should be on with ati cards also? Marco Quote
Gioxy Posted February 12, 2008 Posted February 12, 2008 Nvidia bug should be on with ati cards also? It was named "NVidia bug fix" only because it was noticed for the first time with NVidia cards, but it affect also ATI cards. BTW, I can't be sure it is necessary in your configuration; most probably it was, but you can simply try untickening it and see what happens. If you want dig more on this you can refer to this topic... Quote
