Bjur Posted February 19, 2008 Posted February 19, 2008 I'm using DVBV a lot, especially with recordings, but after being switched to the newest version, I can't get the DVB subtitles to work on the channels. Furthermore I can only see DVB subtitles on recorded Discovery Atlas HD through VLC. If I'm using either DVBViewer or Zoomplayer, I can't get the subtitles, which irritates me, since I'm primary using the two programs. 1. Is there a solution? It can't be right, that I can't see subtitles in DVBViewer any more and why can I see them in VLC? 2. Have heard from several other Danish members that they also have problems with seeing DVB subtitles. However one posted that he got version 3.9.1.1 which they are working, but now the only available is 3.9.2. Why don't they arkivate the versions and how do I find this partically version? Quote
IRa Posted February 19, 2008 Posted February 19, 2008 after being switched to the newest version, I can't get the DVB subtitles to work Do you have "enable if available" selected in settings / subtitle (and right language also) in Finland DVBsubs works even with the newest version, however they worked better with 3.9.1 (but ot so well as in VLC), problem is in timing. Quote
Gioxy Posted February 19, 2008 Posted February 19, 2008 (edited) @Bjur: please don't take this personally... Why don't they arkivate the versions and how do I find this partically version? ...but I'm sincerely wondering why there was so many DVBV users that don't archiviate themselves the old DVBV setup files in their own PCs... Edited February 19, 2008 by Gioxy Quote
Bjur Posted February 20, 2008 Author Posted February 20, 2008 Do you have "enable if available" selected in settings / subtitle (and right language also) in Finland DVBsubs works even with the newest version, however they worked better with 3.9.1 (but ot so well as in VLC), problem is in timing. Yes but it doesn't solve my problem:( I know many other Danish DVBV members has the same problem. @Gioxy: Well I'm a fairly new user to DVBV and thought that when the DVB subs worked on the earlier versions, why change that? And furthermore the program is small, so it shouldn't be a problem to make perhaps an ftp with earlier versions, but from now on, I for sure make backups. PS. I'm still looking for 3.9.1.1 if someone has it! Quote
Derrick Posted February 20, 2008 Posted February 20, 2008 ..if there are many danish users who have similar problems at least one of them should be able to provide a test recording to examine the cause, if there's any Quote
Bjur Posted February 20, 2008 Author Posted February 20, 2008 (edited) ..if there are many danish users who have similar problems at least one of them should be able to provide a test recording to examine the cause, if there's any http://www.DVBViewer.info/forum/index.php?...amp;hl=subtitle And example: http://rapidshare.com/files/88599744/01-31...d_Sport.ts.html Edited February 20, 2008 by Bjur Quote
Bjur Posted February 27, 2008 Author Posted February 27, 2008 http://www.DVBViewer.info/forum/index.php?...amp;hl=subtitle And example: http://rapidshare.com/files/88599744/01-31...d_Sport.ts.html so?????? Quote
