DVB Crashes when playing specific frequency
Polynomials
I have been using DVBViewer Pro with my DTMB USB TV Stick for a couple of weeks. It is a delightful experience to use except for the below problem. When I played a particular channel, DVB will crash after 2-5 minutes. When I played other channels, it works perfectly. There are 3 frequency carrying channels:
482 MHZ: 4 MPEG-2 channels 720p
586 MHZ: 2 H.264 720p channels + 1 H.264 1080i channels
602 MHZ: 5 H.264 720p channels
When I play the 602 MHz channels, it always crashes without any reason. The reception should be fine. It should not be the problem of H.264 decoder either as when I play the other channels (586 MHz), it plays fine. It is most likely that it is a reception problem because the signal of this frequency is the weakest, but it will crash even when the signal is good. Even when the signal of the other frequencies are bad, the DVB would not crash easily.
If you need any system info from me, please ask me. One thing to note is that the ram I have should be 3006MB (4*1028 MB but vista can just recognize 3006MB), not as what is written in the report (2048MB).
Thanks
Thanks
I think I have missed some information :)
TV Card Model: Magic Pro DMB-T/H Stick
MB: Asus P5B (P965)
Graphic Card: GF 7900GS, Driver: 169.25 (which should be the latest)
