Lars_MQ Posted March 10, 2008 Posted March 10, 2008 Program Association Table Program Map Table Service Description Table. If you want to know exactly what they are, maybe you start getting aquainted with google Quote
Derrick Posted March 10, 2008 Posted March 10, 2008 PAM not PMT -> e.g. Pulse Amplitude Modulation Quote
doublejay Posted March 10, 2008 Author Posted March 10, 2008 PAM not PMT -> e.g. Pulse Amplitude Modulation Well........ it was a leading question... What might cause DVBViewer to red-light each of these - despite have a strong signal ?? It's in connection with my earlier post - about it failing to tune a number of channels - that seem no problem to WinTV (Hauppauge )/ http://www.DVBViewer.info/forum/index.php?showtopic=25281 Quote
Lars_MQ Posted March 10, 2008 Posted March 10, 2008 Try using transedit for scanning (see membersarea). Maybe the transponderlist is wrong/not complete. Transedit has a lot of detailed setting and you can export the scanned channels to the DVBViewer. Maybe it's the hardware options (-> Stopstream/ new tuning method) which need to be tweaked. There can be some causes for this, but since you did not respect the How to post problems/bugs correctly:Always follow these instructions. Otherwise no one can - or wants - to help you!. (see at the top) it's hard to say. Quote
doublejay Posted March 10, 2008 Author Posted March 10, 2008 (edited) Ok here is support.zip plus - i tried transedit - and it just reported visibility of 109 channels. obviously i'll need to take this further - but looks verys promising. does it look like I have screwed up setting for DVBViewer ? how come transedit is seeing so much - if you forgive my ignorance. support.zip Edited March 10, 2008 by Tjod Quote
doublejay Posted March 10, 2008 Author Posted March 10, 2008 I exported the transedtit channel list for DVBViewer. Even though it now has all the data about the signal - it doesn't tune it. Yet all of the channels Preview perfectly in transedit. Quote
