keys Posted March 14, 2008 Posted March 14, 2008 (edited) Hello, When i switch from 1 TV channel to an other TV channel or when starting DVBViewer (randomly) i have a black screen with DVBViewer : problem ! Sometimes about 20 seconds after the black screen DVBViewer crash and i need to reboot the pc as process DVBViewer.exe stays on memory, and it's impossible to kill it. If i switch to recorded video when black screen i've correct display & sound. That's why i imagine it's a problem of tuning transponders with my firedtv-s2 card ? If i install the BDA drivers of my firedtv no problem ! I fact i've installed the MCE drivers : provided by Digital everywhere compliant with DVBViewer that make my firedtv card visible as a DVB-T card). This allows to use MCE Vista for watching TV SD and DVBViewer for viewing TV HD. I don't want to install BDA drivers as if i install BDA driver MCE will not work. Any idea ? My config : - vista - Digital everywhere Firedtv-s2 - see also file attached Best regards Keys Edited March 14, 2008 by keys Quote
keys Posted March 14, 2008 Author Posted March 14, 2008 The support file zip is attached to this post ... support.zip Quote
keys Posted March 17, 2008 Author Posted March 17, 2008 Hello, I'm now able to explain better the problem and reproduce it : In fact the black screen appears randomly after a close / start DVBViewer : Exemple : Reboot the pc DVBViewer starts ok and is able to tune all channel close DVBViewer start DVBViewer Pb black screen close DVBViewer start DVBViewer able to tune all channel close DVBViewer start DVBViewer able to tune all channel close DVBViewer start DVBViewer Pb black screen ... So in fact everytime i reboot the pc tuning channel on start DVBViewer works Randomly after close DVBViewer pb black screen Randomly after close DVBViewer no problem with tune channel I will appreciate an help ! Best regards Keys The support file zip is attached to this post ... support.zip Quote
Derrick Posted March 17, 2008 Posted March 17, 2008 ..change video and audio decoder to e.g. cyberlink (PDVD7). According to the hardware.xml your card is detected as a BDA device Quote
keys Posted March 17, 2008 Author Posted March 17, 2008 (edited) I don't understand : What is the link between cyberlink (PDVD7) : video decoder & my firedtv card ? I guess i need to change the config of my firedtv card but why video and audio decoder ? What do i have to change in the config of my firedtv card in hardware.xml ? hardware.xml contents : <section name="@device:pnp:\\?\avc#digital_everywhere&firedtv_s2__&typ_5&id_0#d200000434871200#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}\{9c365890-165f-11d0-a195-0020afd156e4}"> <entry name="HasCI">1</entry> <entry name="UseHardwareFilter">1</entry> <entry name="DVBS2">1</entry> <entry name="Name">FireDTV BDA Tuner DVBS2</entry> <entry name="TunerType">2</entry> <entry name="Status">1</entry> <entry name="InstID">FireDTV BDA Tuner DVBS2 0</entry> <entry name="DeviceNr">1</entry> <entry name="Priority">2</entry> <entry name="ClassID">{EAFB3270-65C7-4662-99D6-C06D5E009FA3}</entry> <entry name="Groups">7</entry> </section> ..change video and audio decoder to e.g. cyberlink (PDVD7). According to the hardware.xml your card is detected as a BDA device Edited March 17, 2008 by keys Quote
Derrick Posted March 17, 2008 Posted March 17, 2008 The link is that the screen remains black if the system can't build a working direct show graph. Decoders be changed in -> options -> directx I've just mentioned BDA cos you wrote > "I don't want to install BDA drivers as if i install BDA driver MCE will not work." Quote
keys Posted March 17, 2008 Author Posted March 17, 2008 (edited) ok thanks Which decoder do you want i install as you can see in file attached there's many cyberlink decoders. For hd i already installed : CyberLink H.264/AVC Decoder (PDVD7.x) V2.1.0.1108: 00600400 and i have the problem ... For mpeg i installed : MPV Decoder Filter V1.0.0.3: 40000002 as it's the more stable decoder for my system, i've trouble with the decoder cyberlink ... Also I don't understand why with the bda driver i don't have black screen... Regards The link is that the screen remains black if the system can't build a working direct show graph.Decoders be changed in -> options -> directx I've just mentioned BDA cos you wrote > "I don't want to install BDA drivers as if i install BDA driver MCE will not work." Systeminfo.txt Edited March 17, 2008 by keys Quote
keys Posted March 20, 2008 Author Posted March 20, 2008 Hello, Can i have news from the support please ? Changing decoders to Cyberlink PDVD 7 does not correct the problem ... Thanks in advance Keys ok thanks Which decoder do you want i install as you can see in file attached there's many cyberlink decoders. For hd i already installed : CyberLink H.264/AVC Decoder (PDVD7.x) V2.1.0.1108: 00600400 and i have the problem ... For mpeg i installed : MPV Decoder Filter V1.0.0.3: 40000002 as it's the more stable decoder for my system, i've trouble with the decoder cyberlink ... Also I don't understand why with the bda driver i don't have black screen... Regards Quote
