Chinese (Traditional/Simplified) Language File
sickno
Please note that the language file supplied in 3.9.4.10 beta is older than the version listed below, so you will need to download the file after upgrading to 3.9.4.10
If you want DVBViewer to be displayed in Chinese (Traditional) language, you will need the following:
Updated! *NEW* 3.9.4.10 4 Jul 2008
Chinese_Traditional_3.9.4.10.zip
Unzip the file to C:\Program Files\DVBViewer\Language to replace the file supplied in 3.9.4.10, and then change the language settings in DVBViewer
For Chinese (Simplified), you will need the following:
Chinese_Simplified_3.9.4.10.zip
Edited by sickno
The attached Chinese (Traditional) Language file for 3.9.3.26beta file is marked as Alpha 4 , but most of the Menu Items and Option Dialog boxes are translated into Traditional Chinese already.
Updated! *NEW* Alpha 5
Apart from h_xxxx items in OSD, all keys are now translated
Please let me know if you are having problems with the translations, thank you!
Older versions (outdated):
As your request, here is the file.
Gary, can you update the Simplified Chinese version to 3.9.3.26beta, thank you! ;)
Edited by sickno
updated the Simplified Chinese version to 3.9.3.26beta
In addition, you can also use "convertz" software to convert the Big-5 .lng file to GBK .lng
Updated to 3.9.3.41b.
Please note that the language file supplied in 3.9.3.41 is older than the version listed above, so you will need to download the file after upgrading to 3.9.3.41 beta.
Edited by sickno
  • 1 month later...
  • 1 month later...
  • 1 month later...
I just post this at the end of this topic, because i'm not sure if the content is correct. I received a "corrected"? version for the simplified translation - since it seems to be that
... especially the latest version 3.94 support Chinese language is good for lots of chinese users. But I found the translation of chinese(Simplified) language file was made by a hongkong guy(Chinese Traditional area). So it's not in accord with our code of language. ...
Christian
PS: Maybe somebody could check this file?
Chinese__Simplified_By_Moff.zip
Christian
thx.it is a better simplified translation.
thanks you~~
  • 5 weeks later...
Hi
thanks for your kind support.
I live in HK and now using the latest version of DVBViewer. I have also updated your language file.
However, I found some pages of EPG guide cannot show the chinese character in the column view.
any idea what I need to set?
i am using XP (english) - i did change the regional setting to HKSAR already
Danny
  • 11 months later...
哗~~可以打中文啊
哪里有4版本的下载?
Edited by 32592878
