safcsat Posted April 3, 2008 Posted April 3, 2008 Hi there. For some reason with all versions of DVBViewer (and alsop other sw like dreamdvb, progdvb etc..) I cannot find ANY DVB-S2 HD channels (channel 4 hd, sky sports hd etc etc..) on any satellites. All I can find are DVB-S channels like BBC HD and Luxe TV HD. I have a FloppyDTV DVB-S2 card and running Windows XP. Also have Motorised dish and have tried two LNB's. Anyone have any ideas? Quote
Benarty Posted April 3, 2008 Posted April 3, 2008 Post the support.zip. I have the floppy DTV DVB-S2 also and no problems to scan the HD channels. I can not view to HD channels except when I remove the cam module , not a problem yet cause out TV support not yet HD material. Quote
Griga Posted April 3, 2008 Posted April 3, 2008 Astra 28° East, right? I have the floppy DTV DVB-S2 Requires special parameters for DVB-S2 reception. They must be included in the transponder list that is used for scanning, otherwise it won't work. Make sure that you are using an up-to-date DVBViewer version. Store the attached transponder list in the DVBViewer configuration folder\transponders (see About -> Configuration Folder in DVBViewer). Remove the old 0282.ini. Restart DVBViewer. Select the new transponder list (Astra/Eurobird 28.2°E) for scanning. Astra_28E.ini Quote
safcsat Posted April 7, 2008 Author Posted April 7, 2008 Thanks for te replies. Tried using that new ini to scan with but still missing a lot of channels (channel 4 hd for example) - however, i DO now receive some of the sky uk dvb-s2 channels.... Missing about 600 chanels though only finds approx 300, usually about 900 i think? Quote
Derrick Posted April 7, 2008 Posted April 7, 2008 My last scan with trasnedit of 0282.ini yielded 1108 channels including dvb-s2. Without dvb-s2 1010 channels.. Quote
safcsat Posted April 10, 2008 Author Posted April 10, 2008 Just done it again with latest transponders list with transedit and got them all!!! Thats VERY strange. Im happy now though!! Thanks everyone Quote
