themaster1 Posted April 30, 2008 Posted April 30, 2008 I have bought a monobloc lnb in order to receive 2 sats hotbird 13° east/astra 19° east the which understand diseqC 1.0. instructions. My dish point toward Hotbird, so hotbird would be position A i believe What would be a suitable configuration for these 2 sats in DVBViewer (v3.92) Example HB : position A/option A Astra : position A / option B or else? Also, What am i supposed to enter in the diseqC editor ? I appreciate your help Quote
Darwin Posted April 30, 2008 Posted April 30, 2008 If Hotbird 'first' LNB and to use adjusting the dish (see monobloc doc), then Hotbird = PosA/OptA and Astra 1 = PosB/OptA Quote
themaster1 Posted April 30, 2008 Author Posted April 30, 2008 If Hotbird 'first' LNB and to use adjusting the dish (see monobloc doc), then Hotbird = PosA/OptA and Astra 1 = PosB/OptA Well i found out, strangely enough it's the following one: Astra 19° = PosA/OptA Hotbird 13°= PosB/OptA HB being the sat my dish point to, so that's kind of mysterious. Quote
Derrick Posted April 30, 2008 Posted April 30, 2008 ..no, it's not mysterious It depends on the switch and the wiring inside your monoblock. Where your dish is pointing is not relevant for diseqc. Standing behind your dish, Astra 19E is more to the left and Hotbird is more to the right, if the dish is pointing in between. Because the dish is a mirror, the left lnb of the monoblock receives the signal from the right satellite (hotbird) and viceversa. If the left lnb is connected by A/A Astra will be B/A. Quote
themaster1 Posted April 30, 2008 Author Posted April 30, 2008 ..no, it's not mysterious It depends on the switch and the wiring inside your monoblock. Where your dish is pointing is not relevant for diseqc. Standing behind your dish, Astra 19E is more to the left and Hotbird is more to the right, if the dish is pointing in between. Because the dish is a mirror, the left lnb of the monoblock receives the signal from the right satellite (hotbird) and viceversa. If the left lnb is connected by A/A Astra will be B/A. I understand the mirror principle but i still don't understand the Pa/Ba / Pb/Ba principle My logic being the following one: The default LNB of this monobloc is HB (LNB on the left) (that's for certain) hence, in my mind, the assumption i made HB= Position A Astra = Position B I guess i should open the monobloc for an insight lol Actually we should discuss semantics i believe: what means "Position" and what means "Option" as far as DiseqC is concerned. Quote
Derrick Posted April 30, 2008 Posted April 30, 2008 I guess i should open the monobloc for an insight lol ..no need for opening. You have a 50% chance to get it right at the 1st try Quote
