steve Kiwi Posted May 11, 2008 Posted May 11, 2008 Have any kiwis or any Norwegians worked out how to edit programmes recorded in DVBViewer. NZ uses H264 with HE-aac audio. I am running XP Pro DVBViewer 3.9.2 with cyberlink H264 codec and monogram multi media AAC decoder version 0.95. And a Hauppauge HVR 1100 tuner card. Can only use DVBViewer for great pictures and sound. Any other software, player (Qt Alt, m player. windows media player... ) or editor (womble) either crashes or does not recognise file. Any help appreciated The editing and conversion forum is all in German so not much help there. Quote
66sayegh Posted May 14, 2008 Posted May 14, 2008 Can only use DVBViewer for great pictures and sound. Any other software, player (Qt Alt, m player. windows media player... ) or editor (womble) either crashes or does not recognise file. In Vista, if you have PowerDVD 8 codecs installed, you can use Windows Movie Maker and Windows DVD Maker to edit and burn the recorded NZ .ts files. You can also view recorded ts from My Videos in Media Center if you have a mind to. Quote
steve Kiwi Posted May 14, 2008 Author Posted May 14, 2008 O for oarsome I haven't got vista but I have a friend that does. I have XP and will try it in movie maker thier too. Quote
PhilW Posted June 1, 2008 Posted June 1, 2008 Have any kiwis or any Norwegians worked out how to edit programmes recorded in DVBViewer.NZ uses H264 with HE-aac audio. I am running XP Pro DVBViewer 3.9.2 with cyberlink H264 codec and monogram multi media AAC decoder version 0.95. And a Hauppauge HVR 1100 tuner card. Can only use DVBViewer for great pictures and sound. Any other software, player (Qt Alt, m player. windows media player... ) or editor (womble) either crashes or does not recognise file. Any help appreciated The editing and conversion forum is all in German so not much help there. Could you not just alter the Option->recorder->output format to mpg? (video/Audio PS (*.mpg), BTW, it's a pityy that the Optus D1 Sat transponder does not seem to be in the list still. Phil Quote
steve Kiwi Posted June 2, 2008 Author Posted June 2, 2008 No tried that(.mpg). But still get a .ts file. But I have noticed TV3 have started broadcasting in AC3. TVNZ shouldn't be far behind. This may open up a few more conversion editing options. .........Any suggestions people??? Quote
AceVPD Posted June 3, 2008 Posted June 3, 2008 In Vista, if you have PowerDVD 8 codecs installed, you can use Windows Movie Maker and Windows DVD Maker to edit and burn the recorded NZ .ts files. You can also view recorded ts from My Videos in Media Center if you have a mind to. Hey 66sayegh Do tell how to be able to play back the TS files in Vista Media Center. thanks Ace Quote
ElecardFAN Posted June 3, 2008 Posted June 3, 2008 Keep in mind NZ and Norway use H264 and AAC+ for Audio and Video. Both formats can not be stored as Mpeg. To play Transportstreams back under Windows Mediacenter you need a Splitter which does that. I'm not sure if Haali Splitter in its latest version is capable to deal with AAC, because the only player which really handles this is the DVBViewer. Find cut tools is also a pain in the ---------------, there are only a few which can be used for H264 at all. Peter Quote
Griga Posted June 3, 2008 Posted June 3, 2008 I'm not sure if Haali Splitter in its latest version is capable to deal with AAC Not with LATM AAC, as it is used in Norway and NZ. Up-to-date versions of the Elecard Demultiplexer can handle it and enable H.264/LATM AAC TS playback in other players, as far as I know. The Elecard Demultiplexer is part of this package. Both formats can not be stored as Mpeg. They can, but it's very unusual, so I wouldn't count on it. The TSPlayer (see members area, tools section, when the server is up again) is able to convert H.264/AAC TS to a program stream resp. MPG file. Quote
PhilW Posted June 3, 2008 Posted June 3, 2008 OK, I'm not sure if I am off track but I connect to these transmissions via sat Optus D1. I understand that there are VHF terestrial transmissions also ? at HDef level which I can't get, hence Satellite. Maybe this is where we differ. The Sat stream in Channel editor is either saved as video=MPEG2/H.264, Audio=MPG/AC3/AAC. For general utility I chose the MPG settings.... I downloaded a compilation of CODECs eg K-Lite Mega Codec Pack, and have Cyberlink software with inbuilt codecs.., which is the codec assigned to H.264/AVC. It seems to do everything seemlessly from there. Quote
