atisnz Posted May 13, 2008 Posted May 13, 2008 Hi, I just bought DVBViewer, and it crashes my pc right after I select a channel. The BSOD says, that the problem is with ativvaxx.dll at address BF56E2E. Please find the support.zip attached. support.zip Quote
Lars_MQ Posted May 13, 2008 Posted May 13, 2008 ativvaxx.dll This is part of the ATI driver. You habe a problem with your driver, please check a older/newer version of the driver. Quote
atisnz Posted May 13, 2008 Author Posted May 13, 2008 I guessed that, but I tried the latest Catalyst and Omega drivers too with the same result. As I'm using a AMD 780G motherboard, there won't be many earlier drivers available. Can you tell from the logs what exactly is clashing with the ATI drivers? It must be some HD component because the analog tv works fine. I have also tried a different filter combinations, without any luck... Quote
atisnz Posted May 15, 2008 Author Posted May 15, 2008 Now I tried the card in a different comp, and the card was installed properly, but DVBViewer does not find it!! What am I doing wrong?? Quote
atisnz Posted May 16, 2008 Author Posted May 16, 2008 I'm getting very frustrated with this program. Just reinstalled to Vista so don't blame the drivers anymore! Installed Powerdvd 7, DVBViewer, and the AAC found in the members section I was getting error: "Cannot render mediafile/output pin 0x8004002". The TV was showing but had no sound... so, I registered the monogram AAC. Now DVBViewer does not shows anything and usually hangs!!! What is wrong??? New support.zip attached. support.zip Quote
Valts Posted May 19, 2008 Posted May 19, 2008 I'm getting very frustrated with this program. Just reinstalled to Vista so don't blame the drivers anymore! Installed Powerdvd 7, DVBViewer, and the AAC found in the members section I was getting error: "Cannot render mediafile/output pin 0x8004002". The TV was showing but had no sound... so, I registered the monogram AAC. Now DVBViewer does not shows anything and usually hangs!!! What is wrong???New support.zip attached. First problem was with drivers. If there was no sound there was a problem with decoding it. If you REALLY need AAC - then use libfaad2 wrapper. Most likely you simply need AC3Filter for all the mpeg audio decoding needs. Quote
atisnz Posted May 23, 2008 Author Posted May 23, 2008 (edited) I reckon, the source of my previous problems was the graphics driver (ATI) which didn't work with the mpeg4 coding. Now I have a new motherboard with Geforce 9600GT graphics. My problem is, that DVBViewer does NOT detects tha tv card (Hauppauge HVR-4000) at all despite I just installed all the latest drivers from all vendors. Why DVBViewer does not detects the TV card when I want to scan for channels???!!! Please see the new support.zip attached! support.zip Edited May 23, 2008 by atisnz Quote
