ardua97 Posted May 19, 2008 Posted May 19, 2008 hello i use DVBViewer por 3.9.2 on windows vista SP1 htpc when i select evr as directx the immage is wrong troubled like this (I attach a printscreen) there is a solution i attach also the support.zip Quote
ardua97 Posted May 19, 2008 Author Posted May 19, 2008 (edited) i'm not able to attach support.zip Edited May 19, 2008 by ardua97 Quote
ardua97 Posted May 19, 2008 Author Posted May 19, 2008 i had compress the immage , deleted some old attach and now i am able to attach immage and support.zip support.zip Quote
ardua97 Posted June 3, 2008 Author Posted June 3, 2008 i had compress the immage , deleted some old attach and now i am able to attach immage and support.zip can anyone help me ? Quote
Klaus_1250 Posted June 7, 2008 Posted June 7, 2008 Try switching codecs. I noticed from the support.zip that you have rather a large amount of codecs installed, including some rather old ones. I would start by cleaning those up. Deinstall codecs and codec-packs. Google for either good codec-packs or purchase them. You can also try ATi's ones (Avivo1K). Quote
ardua97 Posted June 9, 2008 Author Posted June 9, 2008 i had installed the new version 3.9.4.0 but the problem is the same Try switching codecs. I noticed from the support.zip that you have rather a large amount of codecs installed, including some rather old ones. I would start by cleaning those up. Deinstall codecs and codec-packs. Google for either good codec-packs or purchase them. You can also try ATi's ones (Avivo1K). --Try switching codecs in the directx option menu ? you mean to change "decoder video mpeg2" for example I am afraid of disinstall the codecs Quote
Klaus_1250 Posted June 9, 2008 Posted June 9, 2008 (edited) Yup. You currently have these active (from the support.zip): <section name="MPEG"> <entry name="Videocodec">Elecard MPEG-2 Video Decoder</entry> <entry name="Audiocodec">Elecard Audio Decoder</entry> <entry name="AC3codec">Elecard Audio Decoder</entry> <entry name="H264codec">ATI MPEG Video Decoder</entry> <entry name="DetectVideo">0</entry> <entry name="DetectAudio">0</entry> <entry name="AACcodec"><System Default></entry> <entry name="Postprocessor"><None></entry> <entry name="FileDVBSource">1</entry> <entry name="NVidiaFix">1</entry> </section> Try Switching to "CyberLink Video/SP Decoder (PDVD7)" as MPEG2 Video Decoder, and use "CyberLink Audio Decode (PDVD7.x)" as MPEG Audio decoder. Also, are you using Overlay, VMR7, VMR9 or EVR? Try switching between Overlay, VMR7 and VMR9. Also try to see if ticking/unticking (Nvidia) VMR Fix solves the issue (for some reason it says nVidia, but is also solves issues with ATi). But really really, clean up your codecs! In the list for your system, I see very ancient ones, beta ones (don't ever use beta's unless you know how to remove them), trial-version and broken codecs. Here is the list you have on your system: -------------------------MPEG2 Video Decoders: ------------------------- Elecard MPEG-2 Video Decoder V1.0.215.60621: 00800001 Elecard MPEG2 Video Decoder: 00700000 (File is missing) CyberLink Video/SP Decoder (PCM45) V8.0.0.1808: 00700000 CyberLink Video/SP Decoder (PDVD7) V8.0.0.1710: 00602000 Nero DVD Decoder V5.1.2.0: 00600000 Nero Video Decoder V5.1.2.0: 00600000 MainConcept MPEG Video Decoder V1.0.0.78 (beta): 00600000 PCM Video/SP Decoder V8.0.0.1808: 00600000 CyberLink Video/SP Decoder (ShEX) V6.0.0.3202: 00600000 ATI MPEG Video Decoder V9.14.0.4873 (beta): 005FFFFF Microsoft MPEG-2 Video Decoder V11.0.6001.7000: 005FFFFF CyberLink Video/SP Decoder V6.0.0.1919: 005FFC18 Nero Video Decoder HD V5.1.2.0: 00400000 InterVideo NonCSS Video Decoder for Hauppauge V4.5.28.238 (beta): 00400000 CyberLink MPEG Muxer V5.0.0.2221: 00200000 CyberLink MPEG Muxer V5.0.0.1727: 00200000 CyberLink Video/SP BD-HD Decoder (PDVD7.x) V8.0.0.6711: 00200000 CyberLink Video/SP Decoder V6.0.0.2412: 00200000 CyberLink SAC Video Decoder(PDVD7 HomeNetwork) V6.0.0.2122: 00200000 CyberLink MPEG Video Decoder V4.0.0.3013: 00200000 ------------------------- H264 Video Decoders: ------------------------- PCM H.264/AVC Decoder V2.0.0.1808: 00700100 CyberLink H.264/AVC Decoder (PCM45) V2.0.0.1808: 00700000 CyberLink H.264/AVC Decoder (PDVD7.x) V2.0.0.1709: 00600400 ATI MPEG Video Decoder V9.14.0.4873 (beta): 005FFFFF MainConcept (Demo) AVC/H.264 Video Decoder V7.3.0.14882: 005FFFFF CyberLink MPEG Muxer V5.0.0.2221: 00200000 CyberLink MPEG Muxer V5.0.0.1727: 00200000 ------------------------- MPEG Audio Decoders: ------------------------- Elecard Audio Decoder V1.5.340.60302: 50000000 Elecard Layer II Audio Decoder V1.0.5.60626: 50000000 AC3Filter V1.3.1.0: 40000000 Moonlight Odio Dekoda: 24111981 (File is missing) MPEG Audio Decoder: 03680001 (File is missing) Nero Audio Decoder 2 V5.1.2.0: 00600000 CyberLink Audio Decoder V6.1.0.4108 (beta): 00600000 MainConcept MPEG Audio Decoder V1.0.0.78 (beta): 00600000 Microsoft MPEG-1/DD Audio Decoder V11.0.6001.7000: 005FFFFF InterVideo NonCSS Audio Decoder for Hauppauge V4.5.28.238 (beta): 00400000 CyberLink Audio Wizard (PCM45) V1.0.0.1215 (beta): 00200910 CyberLink Audio Decoder (PCM45) V6.1.0.3907 (beta): 00200900 CyberLink Audio Wizard V1.0.0.1215 (beta): 00200002 CyberLink MPEG Muxer V5.0.0.2221: 00200000 CyberLink MPEG Muxer V5.0.0.1727: 00200000 CyberLink Audio Decoder (PDVD7 UPnP) V6.0.0.1803 (beta): 00200000 CyberLink Audio Decoder V6.0.0.2114 (beta): 00200000 CyberLink Audio Decoder V6.1.0.3329 (beta): 00200000 CyberLink Audio Decode (PDVD7.x) V8.1.0.7911 (beta): 00200000 CyberLink Audio Decoder V6.1.0.3329 (beta): 00200000 ------------------------- AC3 Audio Decoders: ------------------------- Elecard Audio Decoder V1.5.340.60302: 50000000 Elecard Layer II Audio Decoder V1.0.5.60626: 50000000 AC3Filter V1.3.1.0: 40000000 Moonlight Odio Dekoda: 24111981 (File is missing) Nero Audio Decoder 2 V5.1.2.0: 00600000 CyberLink Audio Decoder V6.1.0.4108 (beta): 00600000 MainConcept MPEG Audio Decoder V1.0.0.78 (beta): 00600000 Microsoft MPEG-1/DD Audio Decoder V11.0.6001.7000: 005FFFFF InterVideo NonCSS Audio Decoder for Hauppauge V4.5.28.238 (beta): 00400000 CyberLink Audio Wizard (PCM45) V1.0.0.1215 (beta): 00200910 CyberLink Audio Decoder (PCM45) V6.1.0.3907 (beta): 00200900 CyberLink Audio Wizard V1.0.0.1215 (beta): 00200002 CyberLink MPEG Muxer V5.0.0.2221: 00200000 CyberLink MPEG Muxer V5.0.0.1727: 00200000 CyberLink Audio Decoder (PDVD7 UPnP) V6.0.0.1803 (beta): 00200000 CyberLink Audio Decoder V6.0.0.2114 (beta): 00200000 CyberLink Audio Decoder V6.1.0.3329 (beta): 00200000 CyberLink Audio Decode (PDVD7.x) V8.1.0.7911 (beta): 00200000 CyberLink Audio Decoder V6.1.0.3329 (beta): 00200000 You have 7 seperate Cyberlink codec installations! 5 of them are betas and very outdated! I also see (file missing) several times. That means the installation is broken. ATi's MPEG decoder is also a beta. You REALLY need to clean out all of those codecs, it is only going to cause problems. Installing new ones is easy. Edited June 9, 2008 by Klaus_1250 Quote
ardua97 Posted June 9, 2008 Author Posted June 9, 2008 Yup. You currently have these active (from the support.zip):Try Switching to "CyberLink Video/SP Decoder (PDVD7)" as MPEG2 Video Decoder, and use "CyberLink Audio Decode (PDVD7.x)" as MPEG Audio decoder. Also, are you using Overlay, VMR7, VMR9 or EVR? Try switching between Overlay, VMR7 and VMR9. Also try to see if ticking/unticking (Nvidia) VMR Fix solves the issue (for some reason it says nVidia, but is also solves issues with ATi). But really really, clean up your codecs! In the list for your system, I see very ancient ones, beta ones (don't ever use beta's unless you know how to remove them), trial-version and broken codecs. Here is the list you have on your system: You have 7 seperate Cyberlink codec installations! 5 of them are betas and very outdated! I also see (file missing) several times. That means the installation is broken. ATi's MPEG decoder is also a beta. You REALLY need to clean out all of those codecs, it is only going to cause problems. Installing new ones is easy. OK and thank you very much but how i can remove them ? Quote
Klaus_1250 Posted June 9, 2008 Posted June 9, 2008 The best way... using the same programs that installed them. They usually put a deinstall program in the same folder where they installed the codec. The may also show up in Add/Remove Programs in the Control Panel (forgot the name it has in Vista). The other way is to use something like Codec Sniper (http://www.videohelp.com/tools/Codec_Sniper) but I'm not sure if that will work with Vista. But be carefull with Codec Sniper, you don't want to remove the wrong codecs (e.g. check and double-check). You can use the codec tweak tool (http://www.free-codecs.com/download/Codec_Tweak_Tool.htm) to check for any broken codecs afterwards. Again, use it with care. Quote
ardua97 Posted June 10, 2008 Author Posted June 10, 2008 The best way... using the same programs that installed them. They usually put a deinstall program in the same folder where they installed the codec. The may also show up in Add/Remove Programs in the Control Panel (forgot the name it has in Vista). The other way is to use something like Codec Sniper (http://www.videohelp.com/tools/Codec_Sniper) but I'm not sure if that will work with Vista. But be carefull with Codec Sniper, you don't want to remove the wrong codecs (e.g. check and double-check). You can use the codec tweak tool (http://www.free-codecs.com/download/Codec_Tweak_Tool.htm) to check for any broken codecs afterwards. Again, use it with care. Thank you very very very very much Quote
