master44tr Posted May 25, 2008 Posted May 25, 2008 Hello, My both players freeze when I first start them. After closing, it works fine. On hd channels my processor usage is 90%-100% in vista and sometimes xp After closing DVBViewer, sometimes I check ram usage, it exceeds. When I look at running programmes I see dvbviwer working. Intel pentium 4 dual core 2. Asus P5LD2VM-SE mainboard 2GB KINGSTON DDR2 RAM 250 GB SAMSUNG 7200 RPM HARD DISK 512 MB ASUS EXTREME 550 ATI Graphic Card Thanks in advance. support.rar Quote
master44tr Posted June 1, 2008 Author Posted June 1, 2008 My problem hasn't been solved yet or I haven't got a single answer to apply. Quote
Lars_MQ Posted June 1, 2008 Posted June 1, 2008 Well why didn't you post a correct support.zip? Always follow these instructions. Otherwise no one can - or wants - to help you!. As you see there is a reason for this to be written on top of the page. You didn't follow the instructions... Quote
master44tr Posted June 1, 2008 Author Posted June 1, 2008 I managed to solve my two problems , freezing and error message while closing. My hd channel problem hasn't been solved yet. I had read the topic above several times and checked other help topics and their support attachments and I believe I hadn't given less information than others. Except for supporttool information. If I can enter the customer site and download that zip file, I will be able to send the information you need. However, I think there is a problem in customers area. Nothing can be downloaded since 3.9.4 version was released, but I want to say that I am very pleased to have this programme and it is very natural to have this kind of site problems because of density. Thank you very much. Quote
master44tr Posted June 2, 2008 Author Posted June 2, 2008 I am posting you my new support information that I created with the supporttool. Thanks support.zip Quote
master44tr Posted June 4, 2008 Author Posted June 4, 2008 I want to show you two thumbnails from my computer in two different players. I chose the same codecs in both players. Here is the result. I know there is something wrong somewhere because DVBViewer must work better. Can somebody help me? Vista Home Premium 32bit Intel Pentium D CPU 2.80 Ghz 2 Gb Kingston 533 ram 512 mb Asus eax550 graphic card 250 Gb Harddisk support.zip Quote
Griga Posted June 4, 2008 Posted June 4, 2008 My both players freeze when I first start them. What do you mean by "first"? After reboot? A test to pinpoint the problem: Let DVBViewer start first with a radio channel (switch to it before closing DVBViewer). Still freezing? Quote
master44tr Posted June 4, 2008 Author Posted June 4, 2008 Yes, after rebooting computer. When it freezes, I go to options and only click apply button it stops freezing and works fine. After closing and starting DVBViewer it no longer freezes. Anyway, as I said before freezing is no problem for me anymore. I am still fighting with hd channel excessivecpu usage. I want to solve it till the Euro 2008. I want to watch Euro 2008 with this DVBViewer which became my number one player in a very short time. Can you help with this? Quote
