McenterFreak Posted May 25, 2008 Posted May 25, 2008 I have this huge problem: I need to reset the FireDTV box constantly (remove the FireWire cable, wait, plug the Firewire cable again). The symptoms are this: Reception is fine, i change channel, then sometimes okay and sometimes black screen. Then only solution is to remove FireWire cable, and plug it in again. Then i works again, with flawless reception on both SD and HD I have tried with XP and Vista, with DVBViewer version 3.9.2.0 and Beta 3.9.2.51, same problem with alle combinations I have installed the latest Firmware on the FireDTV box Quote
Griga Posted May 26, 2008 Posted May 26, 2008 Don't use Options -> Hardware -> Open whole transponder off (unticked), and don't use the LNB_Off Tool. The FireDTV S2 firmware is still a bit buggy in this respect. Quote
McenterFreak Posted May 27, 2008 Author Posted May 27, 2008 Don't use Options -> Hardware -> Open whole transponder off (unticked), and don't use the LNB_Off Tool. The FireDTV firmware is still a bit buggy in this respect. Thanks By the way, what is the LNB_Off tool? Quote
Griga Posted May 27, 2008 Posted May 27, 2008 http://www.DVBViewer.info/forum/index.php?...st&p=102865 An English Readme is included. Quote
molynetor Posted November 13, 2008 Posted November 13, 2008 Don't use Options -> Hardware -> Open whole transponder off (unticked), and don't use the LNB_Off Tool. The FireDTV S2 firmware is still a bit buggy in this respect. i have the same problem with firedtv s2 xpsp2 and DVBViewer 3.9.4. open whole transponder was actived, but now i have changed it and still the same. qnly can watch 1-2 channels and restart firewire. Status for device 1 Model : FireDTV S2 GUID : 0x001287340400088B HW Ver.: 01.34.04 FW Ver.: 1.4.0 Build 21440 Driver : (FIJI) Frontend Status: Power Supply: 0.00V 1394 Bus: 11.16V Antenna: 17.75V Sig.Str.: 100%, BER: 0 Locked : YES Quote
Griga Posted November 14, 2008 Posted November 14, 2008 FW Ver.: 1.4.0 Build 21440 The hardware PID filter issues are fixed in firmware 1.4.3.22510 and later. Quote
molynetor Posted November 14, 2008 Posted November 14, 2008 The hardware PID filter issues are fixed in firmware 1.4.3.22510 and later. i have update to FW Ver.: 1.5.0 Build 22720 and still the same. Quote
