Guest proton Posted June 3, 2008 Posted June 3, 2008 Hi, I have installed DVBViewer but when I try recording something it asks for a password. I did download "another" version to try it out. I liked it so now I bought it and installed it last night. Today I was experimenting with the codecs I have and tried recording HD TV to test quality. And now it keeps asking for my password. Anyone know how to fix this? I have tried searching on here but no luck. Quote
devo Posted June 3, 2008 Posted June 3, 2008 i had this problem running an DVBViewer backup from a previous format of my system, atleast for me uninstalling then reinstalling DVBViewer made it stop asking for my password/serialkey Quote
Guest proton Posted June 3, 2008 Posted June 3, 2008 i had this problem running an DVBViewer backup from a previous format of my system,atleast for me uninstalling then reinstalling DVBViewer made it stop asking for my password/serialkey OK Thanks, I will try that tomorrow and let you know. I'm off to bed now... Quote
Guest proton Posted June 4, 2008 Posted June 4, 2008 OK Thanks, I will try that tomorrow and let you know. I'm off to bed now... OK I tried it and it still asks for a password and user id? Anyone have any ideas? Quote
Tjod Posted June 4, 2008 Posted June 4, 2008 You have installed the DVBViewer including the Configuration Folder? And installed the DVBViewer using you exact password and username you got by mail? Quote
Guest proton Posted June 4, 2008 Posted June 4, 2008 You have installed the DVBViewer including the Configuration Folder? I'm not sure what you mean about the Configuration folder? And installed the DVBViewer using you exact password and username you got by mail? Yes the exact one in my email I cut and pasted it and it works and I dowloaded extra plugins Quote
Tjod Posted June 4, 2008 Posted June 4, 2008 I'm not sure what you mean about the Configuration folder?If you uninstall the DVBViewer via Control Panel > Software it will asking you if you like to remove the Configuration folder. Quote
Guest proton Posted June 4, 2008 Posted June 4, 2008 If you uninstall the DVBViewer via Control Panel > Software it will asking you if you like to remove the Configuration folder. OK I did it and it said "Do you want to remove all of DVBViewer's Components?" I said yes, but when I go back to the folder the are some folders still there? My OS Is Vista 64, if that helps. Quote
Guest proton Posted June 4, 2008 Posted June 4, 2008 I uninstalled it again and renamed the old folder to DVBViewerOLD and installed again and tried to record and it asked for my username and password again. Quote
Tjod Posted June 4, 2008 Posted June 4, 2008 Is it possible to enter the members section with you username and password and download a file? Open the DVBViewer > About > Configuration Folder -> Close the DVBViewer -> delete all files in the Configuration Folder. Uninstall the DVBViewer and reinstall it. Quote
Guest proton Posted June 4, 2008 Posted June 4, 2008 (edited) Is it possible to enter the members section with you username and password and download a file? Open the DVBViewer > About > Configuration Folder -> Close the DVBViewer -> delete all files in the Configuration Folder. Uninstall the DVBViewer and reinstall it. AHA, I see two Configuration folders... Shall I delete them all after install, there is one called DVBViewer and DVBViewer. (with the dot .) OH and yes I did logon to members area to download it again (just in case). Just looked back and the one with the dot vanished? Strange. Will replay asap after deletions and reinstall. Edited June 4, 2008 by proton Quote
Guest proton Posted June 4, 2008 Posted June 4, 2008 Oh I forgot to add that when I uninstall and re-install it remembers my password and username? Is it supposed to do this? Quote
Guest proton Posted June 4, 2008 Posted June 4, 2008 OK I think I fixed it, I just did a uninstall and made sure all folders were deleted. Downloaded a a Reg Clean Program. I re-installed it and viola. I can now record for over a minute. I only tested for over a minute. Seems to work now. YAY... Now onto the jittery pictures... Quote
aktonin Posted June 23, 2008 Posted June 23, 2008 OK I think I fixed it, I just did a uninstall and made sure all folders were deleted. Downloaded a a Reg Clean Program. I re-installed it and viola. I can now record for over a minute. I only tested for over a minute. Seems to work now. YAY... Now onto the jittery pictures... Could you please tell me the Reg Cleaner you used? Thanks. Quote
