knightfire Posted June 27, 2008 Posted June 27, 2008 Hi Guys I have just bought the dvbveiwer , but i cant get it to scan the channels. I have tried the sat card with its original software and it works fine except for finding HD channels. The card shows up in the hardware list in options menu, but just wont scan. it says "Hardware not available". I have uninstalled the Hypermedia software in case this was the the problem, but not joy does any one have any ideas. Vista ultimate sp1 Geforce 8800gs 2 gig ram Kworld DVB-S 100 satellite card Pentium E2160 dual core processor support.zip Quote
knightfire Posted July 1, 2008 Author Posted July 1, 2008 Hi Guys I have just bought the dvbveiwer , but i cant get it to scan the channels. I have tried the sat card with its original software and it works fine except for finding HD channels. The card shows up in the hardware list in options menu, but just wont scan. it says "Hardware not available". I have uninstalled the Hypermedia software in case this was the the problem, but not joy does any one have any ideas. Vista ultimate sp1 Geforce 8800gs 2 gig ram Kworld DVB-S 100 satellite card Pentium E2160 dual core processor Would someone tell me why no one has answered, have i done something wrong??????? Quote
CiNcH Posted July 2, 2008 Posted July 2, 2008 The card shows up in the hardware list in options menu, but just wont scan. it says "Hardware not available". Check, whether it is recognized as DVB-S device by the DVBViewer device scan (satellite device type). Within scan dialog chose a DVB-S frequency list, the one that corresponds to the satellite your dish is pointing to. Make sure no other DVB application is occupying the DVB card. Otherwise DVBViewer fails to open it. Quote
Lars_MQ Posted July 2, 2008 Posted July 2, 2008 Don't play around with options you don't understand. Go options -> hardware -> and enable ALL channelgroups (A B C) again. Then it should work. Quote
knightfire Posted July 2, 2008 Author Posted July 2, 2008 Don't play around with options you don't understand. Go options -> hardware -> and enable ALL channelgroups (A B C) again. Then it should work. thanks guys i,ll take a look!! Quote
knightfire Posted July 2, 2008 Author Posted July 2, 2008 Ok , tried all that still no go. The dvbs card shows in the Hardware list, under options, but not in the channel scan. Where it says current device , it is blank. The driver is a dba driver, and has worked effectivley before. I have uninstalled all other apps that may use the card. Still nothing, several re-installs as well Quote
