won't recognize h.264 codec
barret
Hello
DVBViewer Pro 3.9.4.0, Vista 32bit, TT3200 card
I am having a problem with DVBViewer Pro versions 3.9.2 and 3.9.4. I cannot get h.264 video streams to decode. I get an error on bootup (Cannot render Media File output pin. error: 0x80040218 no combination of filters could be found to render the stream.) In the DirectX setting I show the Cyberlink h.264 Technotrend codec but DVBViewer will not recognize it. I tried installing Elecard but it won't show up as available under the h.264 codec section. I tried FFDshow and it does show up and it cures the error message so at least I get a picture but it is not decoded. I tried all settings and renderer combinations to get FFdshow to work but with no luck. I had no problems with the TE edition and h.264. I was using Elecard and the TE edition recognized it right away. This has to be something simple but beyond my scope of knowledge. If anyone could help I would appreciate it. There is a new h.264 HD mux I would like to watch and the Tennis Channel also.
Chris
have also the
DVBViewer Pro 3.9.4.0 @ TT3200 S2 card
and all FTA channels works fine here with h.264 codecs
Cyberlink H.264/AVC Decoder (PDVD7)
& CoreAVC video Decoder
otherwise ...
which channels not work for you?
which renderer u use?
what is your currently using hardware?
it is here very helpfull to poste the support.zip file.
creating by this ---> http://www.DVBViewer.info/forum/index.php?...st&id=14292
copy the downloaded file in main-directory and execute.
file creating in config-folder
o:)
No h.264 channels work. I tried all renderers Overlay, EMR7 EMR 9 amd Vista Enhanced.
Here is the support zip
Edited by barret
H264 Video Decoders:
ffdshow Video Decoder V1.0.5.1986: FF800001
CyberLink H.264/AVC Decoder (TechnoTrend): 00200000 (File is missing)
You need a H.264 Video Decoder. ffdshow did not work for DVB h.264 and CyberLink is removed.
Thank You
I downloaded the Elecard h.264 codec but DVBViewer won't pick it up. I will try to find the new cyberlink codec to download.
The problem is solved. I now have h.264 video. The TT software pack needed to be downloaded separately from the driver disc in order for the direct x filters to install. Thank you feixen and Tjod for your help. :)
  • 4 weeks later...
The problem is solved. I now have h.264 video. The TT software pack needed to be downloaded separately from the driver disc in order for the direct x filters to install. Thank you feixen and Tjod for your help. o:)
Hello,
Could you please explain a little bit more your solution ? I think that i am facing the same issue.
thank you.
Regards.
Jérôme
Edited by trougloubidchou
