DVBViewer GUI skins
Klausing
How to make a GUI Skin for the DVBViewer Pro
http://en.DVBViewer.tv/wiki/GUI_SkinCompiler
Since version 2.0 you can make your own skin.
All what you need for this you can find here in the Skin Editor Package.
If you create a skin you can post it here in this thread as attachement.
As example i post my old testskin. Maybe it is not the great art, but it was my first step with this skin editor.
What says an old DVBViewerMember? : "Happy skinning!" :idiot:
Steffen
klausing.skin
  • Like 1
Link to comment
  • 1 month later...
PLEASE USE THIS THREAD ONLY TO POST NEW SKINS. NOT FOR DISCUSSION!! THANX.
BITTE BENUTZT DIESEN THREAD HIER NUR ZUM POSTEN NEUER SKINS. NICHT ZUR DISKUSSION!! DANKE.
BTW: In this thread (in german) you can read how to mod the colors of a skin: Forum-Link
Skin-FAQ:
Q: How to install the skins?
A: You'll get them in the DVBViewer-Service-Center. Unzip the file and put the files with the .skin extension into the skin-directory of your DVBViewer Pro installation...
Then go to Options in DVBViewer and select the skin you want. Skins work only with the Pro-Version, not with the GE- and TE-Versions.
Q: What are the skin-sources good for?
A: If You want to alter a skin to your personal needs, then you need the skin-sources. The skin-sources can be found in the DVBViewer-Service-Center.
Q: What about the copyrights?
A: I just changed the colors of this skin. The copyright remains at the designer of the default-skin: AFAIK: Christian Hackbart.
Q: What do I need the skin-compiler/skin-viewer for?
A: If you changed the sources of a skin or if you made your own skin you need to compile the sources into a single .skin-file. This skin-editor can be found in the DVBViewer-Service-Center.
Q: My question is not answered in this FAQ, what now?
A: Go to the DVBViewer Forum, read the forum-rules and ask your question there.
Edited by Technofriend
Link to comment
  • 1 year later...
DEFAULT SKIN
V1.3: Minor color-bugs fixed -> e.g. volume-sourroundings were a bit too light
V1.2: Minor positioning-bug in radio.ini fixed -> position/volume/mute was 1 pixel to high
V1.1: The default-skin delivered with DVBViewer® 2.0 R0/R1 didn't include the radio-skin -> this one does
Link to comment
DEFGOLD SKIN
V1.4: Minor color-bugs fixed -> e.g. volume-sourroundings were a bit too light
V1.3: Minor positioning-bug in radio.ini fixed -> position/volume/mute was 1 pixel to high
V1.2: Changed color of highlighted menue-bar-text -> from grey to brown
V1.1: Fixed the DVBViewer®-Logo in the upper left corner of the radio-skin -> it was to dark
Link to comment
DEFGREEN SKIN
V1.2: Minor color-bugs fixed -> e.g. volume-sourroundings were a bit too light
V1.1: Minor positioning-bug in radio.ini fixed -> position/volume/mute was 1 pixel to high
Link to comment
DEFBLUE SKIN
V1.1: Unimportant bug in the preview-picture -> fixed
Link to comment
DEFBLUEPINK SKIN
Link to comment
DEFPINK SKIN
Link to comment
DEFROSE SKIN
Link to comment
DEFNITEBLUE SKIN
V1.0: Minor color-bugs fixed -> e.g. volume-sourroundings were a bit too light
(It's still not perfect, but I really don't have time by now....)
V0.9a: Only beta version by now....Don't expect to much before january 2004
V0.9: Minor positioning-bug in radio.ini fixed -> position/volume/mute was 1 pixel to high
Link to comment
DEFAULT GER SKIN (Deutsch)
V1.1: Minor kerning-fixes, minor colour-fixes, edited .ini's
V1.0: Thanx to "Unauthorized" for making this translation into the german language
Link to comment
  • 1 month later...
Ich habe diese Frage schon oft gestellt. Im Forum gieng sie immer unter und per PM wurde mir nach mehreren Verweisen gesagt er werde in den nächsten Tagen released und es gebe vielleicht einen Skincontest. Das ist jetzt schon 2 Monate her.
I asked this often, too, but in the forum I mostly got no answer. Then, 2 month ago me was told it will be released in the next days. (sorry for this very bad english :D )
Link to comment
This skin was made by AIS (www.ais.sk) and is part of the DVBViewer setup.exe version 3.2.2 and higher. (Therefore it is not included in the downloadable skin-package.)
  • Like 1
Link to comment
OKeh Grey
Version: 1.1
Author: OKeh
Attention: The skin works only with DVBViewer 3.2.4+
Download in Members Area
Edited by OKeh
Link to comment
admi-ral,
okehgrey skin is integrated in the posting.
It is just the link below the screenshot of the radio station.
the link is pointing to an arcor.de address.
HTH
NameIt
Link to comment
  • 1 month later...
OKeh Blue
Version: 1.0
Author: OKeh
Edited by OKeh
Link to comment
OKeh Green
Version: 1.0
Author: OKeh
Edited by OKeh
Link to comment
OKeh Orange
Version: 1.0
Author: OKeh
Edited by OKeh
Link to comment
OKeh Yellow
Version: 1.0
Author: OKeh
Edited by OKeh
Link to comment
  • 3 months later...
OKeh 2
Version: 1.0
Source: okeh2source.zip
Edited by OKeh
Link to comment
  • 1 month later...
OKeh 2 German (RDS)
Version: 1.0
Source: okeh2ger_source.zip
Edited by OKeh
Link to comment
  • 2 years later...
  • 5 years later...
Hi all.
I would like save skin but i don't understand this
Compiling a skin
To add a skin into the DVBViewer it is necessary to compress and compile it before. For compiling the skin directory all you need is to use the commandline tool "compressor.exe". The command: "compressor dvbexample.skin C:\program files\skinedit\skin\"compiles the skin located in the "c:\program files\skinedit\skin\" directory..
Who can tell me what can i do that?
Edited by dvbviewer.tv
Link to comment
