flatproblem Posted August 11, 2008 Posted August 11, 2008 Hi, Can someone do me a step by step idiots guide to getting a 7-day EPG in the UK? I keep reading 1/2 information like "use the radiotimes xml", HOW do I: a) Find the xml feed? (cant see any links on the radiotimes website) Tell DVBViewer to use the xml file? (can see that each channel has a tick box for "use external EPG" but cant see where to assign that external file?) Many thanks Quote
Frogster Posted August 11, 2008 Posted August 11, 2008 Can someone do me a step by step idiots guide to getting a 7-day EPG in the UK? Not much point doing a guide yet as it is still a beta and "work in progress". The upcoming version will be somewhat different. What I can say is that this http://www.digitalspy.co.uk/forums/showthread.php?t=837707 works just fine today. Quote
mazza132 Posted August 12, 2008 Posted August 12, 2008 Hi, Can someone do me a step by step idiots guide to getting a 7-day EPG in the UK? I keep reading 1/2 information like "use the radiotimes xml", HOW do I: a) Find the xml feed? (cant see any links on the radiotimes website) Tell DVBViewer to use the xml file? (can see that each channel has a tick box for "use external EPG" but cant see where to assign that external file?) Many thanks Hi - not able to give you an idiots guide, but slowly working out how to do this myself. I use http://www.birtles.org.uk/xmltv/ to download/ create the xml files & it seems to have grabbers built in. I seem to get 14 days on a lot of channels. I then use Auto Import XMLTV to import into DVBViewer. I have EPG+ installed, but I'm not sure what advantages that's currently giving me - I'm suspect I'm doing something wrong. Trust that helps. Quote
