mtb Posted August 17, 2008 Posted August 17, 2008 Hi, Just wanted to know if there was a way to automatically start DVBViewer when you want to record a program, usually DVBViewer has to be running before the EPG works. THANKS Quote
Lakeuk Posted August 17, 2008 Posted August 17, 2008 Use the 'DVB Recording Service', an excellent tool for setting/recording programmes without DVBViewer needing to be open, just remember that once DVBViewer is started the service is stopped so when you close it down remember to start up the service - not hard to forget as an icon shows on the taskbar to tell you the status of the service Quote
hdv Posted August 17, 2008 Posted August 17, 2008 Hello, DVBViewer is started the service is stopped so when you close it down remember to start up the serviceif you had install the RecordingService correctly there is a switch in the Plugins menu of DVBViewer. If you try this, the Service will be started after closing DVBViewer. if there was a way to automatically start DVBViewer when you want to record a programfor this you can use the DVB Task Scheduler. You will find it in the Members Area -> http://www.DVBViewer.com/members/ Quote
Lakeuk Posted August 17, 2008 Posted August 17, 2008 if you had install the RecordingService correctly there is a switch in the Plugins menu of DVBViewer. If you try this, the Service will be started after closing DVBViewer. Thanks, sorted, I do like the recording service Quote
