AndersB Posted August 17, 2008 Posted August 17, 2008 When I fastforward in a recording, timeshift or movie playback, DVBViewer sets the aspect ratio wrong. I have a 16:9 display but after fastforward the display incorrectly shows black bars on top and below the picture. I use zoom preset 0 and to get correct aspect ratio back, I have to toogle through the zoom presets back to 0 and then the black bars disappear. This behavior is the same wether I use aspect ratio setting NONE or AUTO. Can this be resolved by any configuration or is this an error? Quote
Dvb-tv Posted August 25, 2008 Posted August 25, 2008 (edited) Possibly DVBViewer or not, possibly a codec problem. Look for an update for your codec, look/ask if others having problems with your codec version choice. Addition look for an update for your bda tuner drivers also, as this can also affect the problem you have. Edited August 25, 2008 by Dvb-tv Quote
Mach5 Posted January 6, 2009 Posted January 6, 2009 When I fastforward in a recording, timeshift or movie playback, DVBViewer sets the aspect ratio wrong. I have a 16:9 display but after fastforward the display incorrectly shows black bars on top and below the picture. I use zoom preset 0 and to get correct aspect ratio back, I have to toogle through the zoom presets back to 0 and then the black bars disappear. This behavior is the same wether I use aspect ratio setting NONE or AUTO. Can this be resolved by any configuration or is this an error? I'm having same problems - did you got this fixed? Quote
AndersB Posted January 6, 2009 Author Posted January 6, 2009 Nope, unfortunately not. It is still an issue in my configuration. I've gotten used to cycle through the zoom presets after FF/REW to restore the correct AR and haven't bothered to look into it again. Quote
Mach5 Posted January 13, 2009 Posted January 13, 2009 Got this fixed using nvidia purevideo decoder option anamorphic/raw as a display type + using overlay mixer as video renderer in DVBViewer. Quote
