magwitch Posted August 19, 2008 Posted August 19, 2008 Hi there, I have the optional CI module connected to a Skystar HD2, but DVBviewerPro V.3.9.4.0 doesn't recognise it. In Settings - Options - Hardware, I have 'CI Module' ticked, but 'External CI (experimental)' is greyed out. Am I missing a file in the DVBViewer folder, or do I need a driver for the CI module? Regards, Magwitch Quote
daniele Posted August 19, 2008 Posted August 19, 2008 Hi there, I have the optional CI module connected to a Skystar HD2, but DVBviewerPro V.3.9.4.0 doesn't recognise it. In Settings - Options - Hardware, I have 'CI Module' ticked, but 'External CI (experimental)' is greyed out. Am I missing a file in the DVBViewer folder, or do I need a driver for the CI module? Regards, Magwitch I can give you only a very little help, saying that's right 'External CI (experimental)' is greyed out cause it lists 'external' CI like WinTV CI USB or Terratec CI USB. Don't know but don't think your CI need to select from that menu. Make sure your CI works fine with included or adviced software, then it should work in DVBViewer also. Quote
Lars_MQ Posted August 19, 2008 Posted August 19, 2008 isn't the skystar hd2 a technotrend labeled card? then you need to select the technotrend support dll in the setup -> additional downloads. Quote
CiNcH Posted August 19, 2008 Posted August 19, 2008 isn't the skystar hd2 a technotrend labeled card? It is a TwinHan derivative (just like the TerraTec Cinergy S2). Quote
magwitch Posted August 19, 2008 Author Posted August 19, 2008 Thanks for the replies guys. Lars, I believe it's a Twinhan VP-1041//Azurewave ADSP400 rebadge. There seems to be a couple of versions of the Skystar HD2. I don't have the Technotrend setup files, all I have is the Technisat driver/application CD that came with the card. Regards, Magwitch Quote
Lars_MQ Posted August 19, 2008 Posted August 19, 2008 Well twinhan works without problems with CI. So (based on the informations you gave) it must be a problem of the CAM module. Quote
magwitch Posted August 19, 2008 Author Posted August 19, 2008 Well twinhan works without problems with CI. So (based on the informations you gave) it must be a problem of the CAM module. OK, thanks. I'll investigate further. Magwitch Quote
daniele Posted August 20, 2008 Posted August 20, 2008 This topic finally reveals to be interesting for me. I just added a new floppy DTV to my old DVBViewer installation. It seems to work well, but I never added FloppyDTV CI support in setup. What kind of functionality adds? And can I simply add missing component without reinstalling DVBV? Quote
Florix Posted October 15, 2008 Posted October 15, 2008 Hi Lars MQ Where i find the technotrend support dll in the setup -> additional downloads and whats the name of the dll and where i put in the *.dll file? Can you write in german ? Florix Quote
Lars_MQ Posted October 15, 2008 Posted October 15, 2008 No, not in the english part. But you could ask in the german section and someone from the team will answer. Quote
