lamine Posted November 9, 2004 Posted November 9, 2004 where can i get multicast.dll plugin from? can you give me the adresse please. thanks Quote
lamine Posted November 9, 2004 Posted November 9, 2004 can you give me the adresse where can i get the multicast.dll plugin please. thanks. Quote
Guest Oliver Posted November 9, 2004 Posted November 9, 2004 http://www.DVBViewer.com/members Bye Quote
Klausing Posted November 9, 2004 Posted November 9, 2004 same address where you downloadet your full version Quote
Etienne Posted February 3, 2005 Posted February 3, 2005 Hi, I've a problem with the multicast plugin. When I play a program on a satellite and when I select "Enable Streaming" in the multicast configuration panel there is 0kbps data rate in the out of the interface. I've completed the network id interface (if it is the IP address of my computer). I'ven't found a detailled documentation about this plugin. How does it works? How can I configure it to play a Mpeg video on my networks? Thanks a lot Etienne Quote
Guest Oliver Posted February 3, 2005 Posted February 3, 2005 http://www.DVBViewer.com/oliver/plugins.html#multicast http://www.DVBViewer.com/oliver/network.htm Bye Quote
Etienne Posted February 4, 2005 Posted February 4, 2005 Hi, Currently, I'm using the multicast plugin. It correctly work but there is no RTP Header detected by VideoLan sofware. Is it normal ? Thanks Etienne Quote
Guest Oliver Posted February 4, 2005 Posted February 4, 2005 Well, the multicast plugin is no longer supported at all, since the DVBViewer Pro 2.5 (release date mid February) will feature a completely new server application which is remotely controlled by a DVBViewer client (that means, there's no longer a need for using 3rd party client software as VLC). The latter was a severe limitation of the multicast plugin. Bye, Oliver Quote
Etienne Posted February 4, 2005 Posted February 4, 2005 Ok,Thanks Oliver Will the DVBViewer 2.5 support RTP protocol (with RTCP) ? Thanks Etienne Quote
Mr_Mirek Posted March 17, 2005 Posted March 17, 2005 Hi, yesterday i've published the Multicast Plugin which allows to: 1. Broadcast the current channel (only video at the moment) 2. Broadcast all other channels available on the transponder This has been tested with Videolan (videolan.org), an own multicast sourcefilter (which is not complete) and the Moonlight Multicast Directshowfilter. The plugin is free for private use, commercial users should contact me first. Feel free to send some test results.. Christian <{POST_SNAPBACK}> HEY PLEASE GIVE ME THE LINK TO DOWNLOAD Multicast.dll Thanks Quote
cable Posted April 27, 2008 Posted April 27, 2008 here hello, i am surya, how to get id and passwd to download this plugin ? best regards, surya. Quote
hdv Posted April 27, 2008 Posted April 27, 2008 Hello, how to get id and passwd to download this pluginto buy the DVBViewer Pro -> http://www.DVBViewer.com/en/index.php?page=ordering Quote
jardus Posted November 30, 2008 Posted November 30, 2008 (edited) Hello, I have paid private section, but I haven't found the multicast plugin in http://www.DVBViewer.com/members/. Can you help me? Thank you. Edited November 30, 2008 by jardus Quote
Tjod Posted November 30, 2008 Posted November 30, 2008 The Multicast Plugin did not exist anymore. And the NetStream Plugin is part of the DVBViewer Setup. Quote
