DVBVIEWER CT-3650 CI + VISTA 64 Bit
Dahl
I Have huge problems regarding Vista 64 Bit and DVBViewer
The problem is not the dvbviwer program i think , because the following happens.
1) Bad Video but perfect sound, the video lags and there is pixel errors, but the signal (DVB-C) i perfect 100 %
2) even worse on the HD Channels, 95 % green and in the top some "action" but perfect sound
can anyone tell me whats wrong ?
I Have attached the support.zip file , hope somehone can explain me what happens, and what to do. Its the same result wether i use EVR or WMR7 or WMR9
I use powerdvd 8 codecs,
It worked fine on my XP but not i Vista....
Kind Regards
Morten
Link to comment
No you don't.
VCodec: Microsoft MPEG-2 Video Decoder, ACodec: Microsoft MPEG-1/DD Audio Decoder
Go options -> directX and set the codecs to cyberlink.
Link to comment
No you don't.
HEY
Thank you , but nothing has changed, even though i changed the codec to cyberlink ver 8.
I think it might be the directx 10, and my graphic card 96oo mobile it says the drivers i not whql approved
any suggetions ?
Link to comment
Download TransEdit from the members section. Choose you satellite, select a frequency and then press the 'Analyze' button. Check out the 'Missing' column...
Link to comment
Thank you
i dont use satellite i use cable. what should i do then ?
nothing happens if i press analyze on a cable frequency
Link to comment
When i get a preview of a free to air channel i trans edit , and press properties, i can see there are no errors , but a discontinuities for every second, the sound is perfect but stille the picture freeze for 5 sek and the a nother frame is showed, and freezees and so on.
morten
Link to comment
Discontinuities are bad, when they are counting up, means that data is missing. Guess you have a ressource problem. Update all drivers (chipset, audio, just everything).
I won't say that this is kind of common to Vista 64. Otherwise some people will jump at me because they think that Vista 64 is "the shit".
Edited by CiNcH
Link to comment
Hey again
Could it be the Tecnotrend CT-360 CI device?
I have tried it on a friends computer, with vista 32 bit, its the same problems?
i know that it has worked on his computer before.
is it because i install everything driver and program wrongfully?
does it have something to do with visual basic program?
Kind Regards
Morten
Link to comment
  • 1 month later...
IT WAS THE DEVICE CT-3650 CI
IT was broken
Morten
Hey again
Kind Regards
Morten
Link to comment
