JOjbert Posted September 9, 2008 Posted September 9, 2008 Hi i have bought an TerraTec Cinergy HTC USB HS and can recive channels with DVB-T but when I try to recive DVB-c DVBViewer says that i have no hardware. I have av Vista Ultimate with AMD and an ATI x1200 graphich board support.zip Quote
Tjod Posted September 9, 2008 Posted September 9, 2008 The DVB-C support for the Cinergy HTC USB XS HD Hyrid is only in 3.9.4.25 BETA and newer. http://www.DVBViewer.info/forum/index.php?...st&p=202530 Currently you have to use the BETA to use this. Quote
JOjbert Posted September 10, 2008 Author Posted September 10, 2008 I saw that later after I posted my meessage so I downloaded the beta and it worked. I found channels but now I have no picture or sound, I can watch Teletext if the channel has it. I tried diffrent kind settings in the Direct X but it doesn´t work anyway. Quote
Tjod Posted September 10, 2008 Posted September 10, 2008 Have you followed the install instructions? Pleas post your support.zip Quote
bo_nk Posted November 27, 2008 Posted November 27, 2008 hi, sorry for the stupid question, but how can i test my device TerraTec Cinergy HTC USB HS, as the transedit demo version is too old one. is it possible to get some other tool or the beta? regards Quote
