aiwa2001 Posted September 11, 2008 Posted September 11, 2008 Hello! Is there anyone with a working DVBViewer setup with CT-3650 usb box? Everything is ok with the bundled tt-mediacenter and when using that also crypted channels open perfectly. I have a Technisat conax cam. With DVBViewer pro 3.9.4.0 there is however no luck at all with decrypting and only FTA channels work. From this forum I understand that the satellite version S2-3650 and DVBViewer works ok with crypted channels and this really confuses me as these technotrend boxes appear to be identical? I hope there is some solution or else I have made an expensive mistake when buying the CT-3650... Quote
Tjod Posted September 11, 2008 Posted September 11, 2008 Is the API dll installed? If no install the CI/Remote support for Technotrend and MS C runtime via start menu > programs > DVBViewer > Support > Modify DVBViewer Pro. Quote
aiwa2001 Posted September 11, 2008 Author Posted September 11, 2008 Hey thanks a lot! I really never had used the download additional software part in DVBViewer installer and always got weather icons etc. manually. Because of this I have never seen the needed technotrend CI addons. This was very simple to fix with your advise and after installing dll and ms runtime now everything runs beautifully. Quote
Thomas Fogh Posted July 21, 2009 Posted July 21, 2009 Is the API dll installed?If no install the CI/Remote support for Technotrend and MS C runtime via start menu > programs > DVBViewer > Support > Modify DVBViewer Pro. Sorry to wake up an old thread, but do I need this for TransEdit MMC (to check if my TechnoTrend CT-3650 CI + Irdetor CAM will work). Thanks! BR, Thomas Fogh Quote
dubarrini Posted July 23, 2010 Posted July 23, 2010 Hi! I have the same problem of the first post. I installed everything needed but encrypted channel won't show. In MediaPortal and TT-Viewer (based on DVBViewer) everything is ok. Any ideas? Thanks in advance Quote
