FrankRizzo Posted September 13, 2008 Posted September 13, 2008 Guys, I REALLY need an answer to this question, and figure you guys might be the ones to ask! When a broadcaster moves a stream from 1 transponder to another, they obviously have to send a msg to their IRDs to tell it that "Channel A" has moved to a new place. Is this msg a part of the DVB spec? Either way, if you can, please point me to info on this event. Thanks! Frank Quote
Griga Posted September 13, 2008 Posted September 13, 2008 Is this msg a part of the DVB spec? No, as far as I know. Here in Germany broadcasters usually insert an information in the TV picture saying that the transponder/frequency will change and a re-scan will be required. Quote
Moses Posted September 14, 2008 Posted September 14, 2008 the dvb-c set-top-box from my cable company checks the NIT on start up and if there is a change in the NIT it performs a scan. Quote
