DVBViewer Pro, Technisat skystar HD2 & diseqc 1.1
petasis
Hi all,
I have bought a skystar HD2 a month now, and I am unable to control part of my satellite installation with it.
Techinsat technical support is not helpful at all, and I don't know what else to do. It all comes down to:
Does the skystar HD2 support diseqc 1.1? Technisat said it does, but I cannot make it work...
The dish is a wavefrontier T90, with 8 LNBs, installed by a professional installator.
All 8 LNBs are connected to a 8->1 switch from maximum. The switch is this:
http://www.kjaerulff1.com/catid.216/pid.796/82.aspx
The manual that came with the switch claims that the switch supports diseqc 1.0, 1.1 & 1.2:
http://www.ellogon.org/~petasis/nova/Diseq...tch-English.png
Now with DVBViewer: I can see the first 4 switch inputs with diseqc 1.0.
All my attempts with diseqc 1.1 failed. And with diseqc 1.2 I had mixed results.
Using diseqc 1.2, I declared the switch as a "positioner". I was able to see the inputs from 5-8, but it was really unstable.
I was able to see input 5 using "position 5" for example, without storing anything in this position. But it was impossible to see inputs 1-4, no matter what "position" I selected.
Then I tried to build a "mixed" channel list: the 4 first satellites using diseqc 1.0, and the last 4 using diseqc 1.2. It worked partially: I was able to switch channels inside a "group" (i.e. the first 4), but I had to restart DVBViewer to tune channels from the second "group". Once I used diseqc 1.0, diseqc 1.2 stopped working, and the opposite.
So, my final test was to use diseqc 1.1. As there is no support for this in DVBViewer, I used the diseqc editor.
Taking as starting point the post:
http://www.DVBViewer.info/forum/index.php?...mp;#entry116033
I tried to setup a command to see LNB 8. All my attempts failed. No matter what uncommitted switch command I used, I could switch only the first 4 inputs.
I am out of ideas :bye: Does anybody know a solution?
What may be the problem? Is it DVBViewer? Is it the drivers? (driver details: Technisat Mantis BDA HID Device version 1.0.1.5, Technisat Mantis BDA Receiver 1.1.0.402, all date 25/1/2008), Is it the hardware?
Is skystar HD2 a good card? Maybe it was a wrong choice and I should buy something better?
Its a pity to have 8 lnbs and be able to see only four of them... :lol:
Finally, the solution was simple: I used as DiseqC the value "Use Positioner", and in the USALS entry beneath the values:
  • INPUT 1 -> Position 0
  • INPUT 2 -> Position 1
  • INPUT 3 -> Position 2
  • INPUT 4 -> Position 3
  • INPUT 5 -> Position 4
  • INPUT 6 -> Position 5
  • INPUT 7 -> Position 6
  • INPUT 8 -> Position 7
  • 3 months later...
Hello,
I did what you wrote in the last post.
It works. DVBViewer can find all 8 satellite and can scan as well.
When I change channels from one satellite to the another I can see nothing only that the quality is strong enough.
After restarting DVBViewer starting with the last channel everithing ok.
It means for me any time when I change satellite I should restart DVBViewer.
Does it happend with you?
How did you solve it?
thx,
wh
  • 9 months later...
can not work for me support.zip copy to there? i work DVBViewer 4.0.0 and diseqc 1.1 and sky star hd2 and canot scan sat 2,3,4,..... please help me
