boulder2 Posted September 20, 2008 Posted September 20, 2008 (edited) I know, I 'm asking a lot of stuff, but I 'm trying things out now, that is why. So, since a while there is a new HD channel available here in Flanders, called "één HD". In reality it has the exact same programming as the regular "één" channel, except that some programs are in HD and most are upconverted to HD. Now, if I want EPG information, I just go to NED2, and wait for a minute, then I get the message that Mediahighway information has been loaded correctly. This imports EPG information for één, VTM, VT4, etc. as well as the Dutch channels. It seems though, that even though "één" and "één HD" show exactly the same programs, only "één" has EPG information. So I 'd like to know, is there any way I could copy that information from één to één HD ? Edited September 20, 2008 by boulder2 Quote
Lars_MQ Posted September 20, 2008 Posted September 20, 2008 No that's not possile. The broadcaster says which epg belongs to which channel and there is no way to influence this. Quote
boulder2 Posted September 21, 2008 Author Posted September 21, 2008 No that's not possile. The broadcaster says which epg belongs to which channel and there is no way to influence this. But the EPG information is probably copied in a database somewhere ? So after it is imported, couldn't I copy the information from één to één HD ? Quote
Lars_MQ Posted September 21, 2008 Posted September 21, 2008 Just have a look at membersarea -> Sources -> epg.dat/channels.dat structure. You just need to manipulate this. Or you could use the COM Interface to copy the data, should be much easier, you just have to adjust the EPGChannelID... Quote
