CAM/CI/Card Not Recognised on FIrst Boot
Neil__C
Hi all,
DVBViewer works pretty much perfectly on my FireDTV-S2, Gigabyte G45, Vista x64 system. My biggest problem is after a reboot where it nearly always fails to recognise the card or cam. The symptoms become apparent in VMC when it shows the subscription channels (Sky UK,[removed]) as encryped (other channels show OK). Exiting and firing up DVBViewer shows the asterisk and a black screen, i.e. the same problem. Pulling the card out and putting it straight back in makes DVBViewer show the channel OK and thereafter so does VMC.
This sounds like a driver issue but Digital Everywhere are as usual failing to reply to anything and a workround might be a little program which 'kicked' the card/cam/ci when windows first starts and then exits. Anyone have any idea if this is possible?
I don't think this is a DVBViewer bug which is why I posted i nthis forum - hope I did right.
Thanks in anticipation.
§ 13
Do not ask for or discuss plugins for descrambling/decrypting pay-tv or key-codes.
Although the DVBViewer Pro provides full pay-tv functionality it must only be used in combination with a valid subscription of a pay-tv provider, a tv-card/box featuring a "common interface" (CI) and the corresponding "common access module" (CAM) with a smart-card. This applies regardless whether software-descrambling is allowed in your country or not.
  • 1 month later...
Hello I post here to avoid creating another post unnecessarily.
I have exactly the same problem with Win XP xp3 + TT S1100 budget + CI.
In disable the "common interface module" and by reactivating immediately after. that's working
There is a command line or manipulation can do that at the start or stop DVBViewer?
Thanks a lot
Edited by Cruelo
