patti Posted October 7, 2008 Share Posted October 7, 2008 (edited) DVBViewer 3.9.4.0 & default skin When watching a recording and pressing OSD OK you get the timeline view which also shows the title, artist (channel) and filename of the recording. The filename only displays the same info as the title (name of the program) and if you have several recordings of the same show then you cannot tell by filename which one you are viewing. Could the filename display the actual filename or would it even be possible to add a "date recorded" info to the timeline view? Thanks Edited October 7, 2008 by patti Quote Link to comment
