raducoc Posted October 12, 2008 Share Posted October 12, 2008 Im using DVB 3.9 and ffmpeg driver that have support for Logo remover. Is working great, FFmpeg is doing the job, the channels logos are desapearing , the only problem is that when Im changing the channel, I need to manualy readjust the position and size of the LOGO REMOVER settings from ffmpeg. I will be great to have an option PER CHANNEL to readjust automaticaly the settings of FFmpeg when Im switching the cannels. Thx in advice. Quote Link to comment
Benarty Posted October 12, 2008 Share Posted October 12, 2008 This is a problem of ffmpeg and not DVBViewer. Also, the channel logo position changes bewteen different channels, some are placed into the black border above of under the video filed so easy to remove, others are placed on top of the video and that's difficult to 'remove' cause a good remove would mean to keep track of the surrounding video changes in realtime. Quote Link to comment
Tjod Posted October 12, 2008 Share Posted October 12, 2008 I dont know if it is possible to readjust the Logo remover via comandline. If yes you can do it via channelchange.vbs Edit the ...\DVBViewer\Scripts\channelchange.vbs Dim ChanLabelsub main(ChannelNr) ChanLabel = none ChanLabel = ChannelManager(ChannelNr).Name Select Case ChanLabel Case "Das Erste" osd.showInfoinTVpic "The chennel name is Das Erste",1000 OSD.ExecNewProcess "C:\WINDOWS\notepad.exe", "", False, False Case "ZDF (AC3,dd)" osd.showInfoinTVpic "The chennel name is ZDF (AC3,dd)",1000 OSD.ExecNewProcess "C:\WINDOWS\notepad.exe", "", False, False Case "3sat (AC3,dd)" osd.showInfoinTVpic "The chennel name is 3sat (AC3,dd)",1000 OSD.ExecNewProcess "C:\WINDOWS\notepad.exe", "", False, False Case Else osd.showInfoinTVpic ChanLabel & " is new chennel no Case create in the channelchange.vbs until now.",1000 End Select end sub replace with your channel names only as test remove if everything work the comandline command Quote Link to comment
