remlap Posted October 14, 2008 Posted October 14, 2008 Hi, I have just discovered a new channel on 9e called BebeTV HD. It uses AAC audio yet I do not have any AAC filters chooseable in DVBViewer yet I can play a recorded TS fine in Media Player Classic which uses a filter called "AAC Decoder" How can I add this to DVBViewer Thanks 2 Quote
Griga Posted October 14, 2008 Posted October 14, 2008 Download from the members area -> plugins -> libfaad2 wrapper... and read the ReadMe! Quote
Derrick Posted October 14, 2008 Posted October 14, 2008 Live sound doesn't work. Playback is ok. Screen shot live from dvbviewer_pro, playback from tsplayer. Quote
Derrick Posted October 14, 2008 Posted October 14, 2008 ..vlc 0.9.4 sounds ok with live stream from the DVBViewer Quote
Griga Posted October 15, 2008 Posted October 15, 2008 Please provide a sample. LATM or ADTS AAC, stream type in the PMT? ADTS live playback was most likely broken in DVBSource 3.2.0, maybe still hindered in 3.2.1 (can't test it), so try the internal 3.2.2, that will be released soon. Quote
Griga Posted October 15, 2008 Posted October 15, 2008 It's working now with DVBViewer Filter 3.2.2 and the libfaad2 Wrapper Filter, as confirmed by Derrick. I do not have any AAC filters chooseable in DVBViewer yet I can play a recorded TS fine in Media Player Classic which uses a filter called "AAC Decoder" DVBViewer only lists AAC decoders that support LATM AAC (a modern AAC stream type broadcasted in several countries) and that are usable for TV/Radio playback with the DVBViewer Filter. BebeTV HD comes with the older ADTS AAC type - a different kind of packaging the audio data, mainly used in East Asia. Thus it is hard to find a test channel that can be received here. Quote
remlap Posted October 17, 2008 Author Posted October 17, 2008 So no way to listen to the audio in DVBViewer? Quote
CiNcH Posted October 17, 2008 Posted October 17, 2008 (edited) So no way to listen to the audio in DVBViewer? Äh It is working... >>>>>> CLICK HERE <<<<<< It's working now with DVBViewer Filter 3.2.2 and the libfaad2 Wrapper Filter, as confirmed by Derrick. Edited October 17, 2008 by CiNcH Quote
Griga Posted October 17, 2008 Posted October 17, 2008 So no way to listen to the audio in DVBViewer? No, if you are not able to read carefully... You'll have to use the libfaad2 wrapper as decoder. It supports LATM and ADTS AAC. Quote
remlap Posted October 17, 2008 Author Posted October 17, 2008 No, if you are not able to read carefully... You'll have to use the libfaad2 wrapper as decoder. It supports LATM and ADTS AAC. Nope nothing will work, it will default to my Cyberlink Audio Decoder even if I select libfaad2. Quote
Tjod Posted October 17, 2008 Posted October 17, 2008 Is the libfaad2.dll in the right folder? What libfaad2.dll are you using? Quote
Griga Posted October 17, 2008 Posted October 17, 2008 Nope nothing will work, I thought so No, if you are not able to read carefully... Including the wrapper ReadMe. Quote
remlap Posted October 17, 2008 Author Posted October 17, 2008 I am seriously a thicko. Thanks guys. Quote
