Dvbviewer with two Airstar 2 tuners
Dallda(CZ)
I had 1 Airstar DVB-T tuner for years and today I decided buy another tuner.
Now my problem is, that I see only 1 device in Options -> Hardware so I do not set whitch tuner has group A or B.
I tried in device manager turn off one device and DVBViewer works fine. When I turn off second device and first turn on dviviewer works fine too.
I try everithing install reinstall DVBViewer pro I try brand new DVBViewer GE (with delete settings).
I want to know how I get 2 device in Option -> Hardware for settings groups.
Thx for your advice.
Dallda
I think you need newer Airstar 2 driver version 4.4 or newer.
You have right. I has only SP1 on my computer for that reason I did use new driver. Today I install all windows updates (SP3) install new driver and now is working fine.
Thx a lot.
