arc03 Posted November 5, 2008 Posted November 5, 2008 Hi all. My previous card was Twinhan-C and I used it with SCM conax cam to watch encrypted channels and it worked OK. Now I have TT-connect CT-3650 CI (USB) and trying to use with the same cam but cannot watch encrypted channels. The difference here is that previous card was for cable receiving and now I'm using T option of TT and other pay-tv providers card. Free to air channels works OK. I have installed the CI/remote support for TT but with no luck. Is there a way to check if the cam is "suitable" for TT use or for the pay-tv provider card? Quote
CiNcH Posted November 5, 2008 Posted November 5, 2008 Is the CAM at least being initialized? See 'View' -> 'Show CAM' within DVBViewer. Quote
arc03 Posted November 5, 2008 Author Posted November 5, 2008 Is the CAM at least being initialized? See 'View' -> 'Show CAM' within DVBViewer. Can't choose it, it's grayed out. So the cam is not suitable for DVBV? Quote
arc03 Posted November 5, 2008 Author Posted November 5, 2008 Did you install the VC2005 SP1 runtimes? Yes I did. And ment not suitable with TT. Quote
CiNcH Posted November 5, 2008 Posted November 5, 2008 I thought it was... Keep in mind that you have to install the x86 version of VC2005 SP1 runtimes (and it must be SP1, otherwise the TT-DLL will not work) even if you have installed a 64-bit system. Quote
arc03 Posted November 5, 2008 Author Posted November 5, 2008 I thought it was... Keep in mind that you have to install the x86 version of VC2005 SP1 runtimes (and it must be SP1, otherwise the TT-DLL will not work) even if you have installed a 64-bit system. Yes, it's SP1. Quote
CiNcH Posted November 5, 2008 Posted November 5, 2008 So it should work. And as I said, it must be the x86 version, not the 64 bit version! Did you try the TT-Media Center and whether it detects the module? Quote
arc03 Posted November 5, 2008 Author Posted November 5, 2008 So it should work. And as I said, it must be the x86 version, not the 64 bit version! Did you try the TT-Media Center and whether it detects the module? Yes, it's x86. No I haven't. But I'll try it aswell. Quote
arc03 Posted November 5, 2008 Author Posted November 5, 2008 Yes, it's x86. No I haven't. But I'll try it aswell. Installed, CI settings flashes but no info available, just asks to wait for info. Quote
CiNcH Posted November 5, 2008 Posted November 5, 2008 Looks like an incompatibility between SCM Conax and 3650 then. Quote
arc03 Posted November 5, 2008 Author Posted November 5, 2008 Looks like an incompatibility between SCM Conax and 3650 then. Yes. Have to find another cam. Thanks for your help. Quote
arc03 Posted November 5, 2008 Author Posted November 5, 2008 Yes. Have to find another cam. Thanks for your help. Bought a new cam. No it works just fine. Quote
arc03 Posted November 5, 2008 Author Posted November 5, 2008 (edited) Which one? Dilog (SmardTV) Edited November 5, 2008 by arc03 Quote
