embrion Posted November 6, 2008 Share Posted November 6, 2008 Hi, I'm using a Pro 3.9.4 version and sometimes, during channel switching the program stops to respond, video freezes and I must use alt+ctrl+del to kill it and start over. Win XP Pro SP3 + Skystar2. VMR9 + ffdshow. Support.zip attached. Btw. where I can find email to the support for licensed users? support.zip Quote Link to comment
Tjod Posted November 6, 2008 Share Posted November 6, 2008 Rename the Plugins folder to Plugins1 did it than still freezes? Quote Link to comment
embrion Posted November 6, 2008 Author Share Posted November 6, 2008 Thanks, I'll try it but how renaming Plugins folder should help? I'm asking from coder's point of view. Quote Link to comment
Tjod Posted November 6, 2008 Share Posted November 6, 2008 If it helps a faulty plugin is the reason for the problem. An by the way I'm not a coder. I helping here in my free time just for fun. There is only one coder who earning money with the DVBViewer. Quote Link to comment
embrion Posted November 7, 2008 Author Share Posted November 7, 2008 Still the same. I'd be suprised if this would be plugins fault as I used them with other dvb programs and had no problems at all. Quote Link to comment
Tjod Posted November 7, 2008 Share Posted November 7, 2008 Pleas start the DVBViewer via star menu > programs > DVBViewer > Support > DVBViewer Pro (Debug Mode) and wait for a freezes. Do this 3-4 Tims and than post a new support.zip. Quote Link to comment
embrion Posted November 9, 2008 Author Share Posted November 9, 2008 Log attached. It was not always in debug mode but it freezed at least twice being in it. support.zip Quote Link to comment
Griga Posted November 9, 2008 Share Posted November 9, 2008 Check if this applies in your case. Quote Link to comment
Tjod Posted November 9, 2008 Share Posted November 9, 2008 You are still using Plugins and at lest on freeze is caused by a plugin. If the tip from Griga did not help. Pleas post a debug.log where the DVBViewer freeze without plugins. Quote Link to comment
embrion Posted November 9, 2008 Author Share Posted November 9, 2008 (edited) Check if this applies in your case. Thanks, I'll check it out. You are still using Plugins and at lest on freeze is caused by a plugin.If the tip from Griga did not help. Pleas post a debug.log where the DVBViewer freeze without plugins. Thank You too. Which line number / date+time in debug.log shows that freeze is caused by a plugin? Edited November 9, 2008 by embrion Quote Link to comment
Tjod Posted November 9, 2008 Share Posted November 9, 2008 Look for Start App one time the Plugin is the last one. If the problem is not caused by a plugin. It should be easy to reproduce the problem without plugins Quote Link to comment
