RichardWhite Posted November 24, 2008 Posted November 24, 2008 When I start DVBViewer 3.9.4.0, Zonealarm pops up a message saying DVDviewer Pro is trying to access the internet. I have disabled automatic update checks, and can't seem to find anything else in the options that should require internet access. Any suggestions what's causing this, and how to get rid of it. Quote
Griga Posted November 24, 2008 Posted November 24, 2008 Just a bug. AFAIK already fixed in the current beta. Quote
RichardWhite Posted November 24, 2008 Author Posted November 24, 2008 Thanks, looking forward to the next release, then. Quote
pvc Posted February 8, 2009 Posted February 8, 2009 DVDviewer Pro 4.0 is still trying to acces the internet ........ Quote
Tjod Posted February 8, 2009 Posted February 8, 2009 Of cause you have to uncheck: Options > News >Autodownload both things Options > Weather > Autoupdate and make sure that you use no Plugin or Decoder that tray to access the Internet. Quote
NanoBot Posted February 9, 2009 Posted February 9, 2009 (edited) Hi, with version 4.0 on XP, even with administrative rights, it is not possible to switch off the option to look automatically for updates. If I switch it off and restart the DVBViewer, it is switched on again. The check for an update results, as wireshark shows, in an SSL encrypted answer. So the bug is still there in version 4.0. And that behavior of the program raises the question: Why is the answer for a simple update check SSL encrypted ? For an update check, it would be enough to send back the version number of the actual version on the server in plaintext and to compare that with the version number of the current installation. May be there is an updated blacklist for stolen serials included in this information ? Well, not a real problem to me, since I am a happy and legitimate user of the DVBViewer. C.U. NanoBot Edited February 9, 2009 by NanoBot Quote
Tjod Posted February 9, 2009 Posted February 9, 2009 with version 4.0 on XP, even with administrative rights, it is not possible to switch off the option to look automatically for updates. If I switch it off and restart the DVBViewer, it is switched on again.That is strange, here on Vista disabling in DVBViewer 4.0.0 works without problems. And if i remember it right i have tryed it although under XP with the 4.0.0 successful.If you changed other thighs with this, are they saved? Quote
