skb Posted December 14, 2008 Posted December 14, 2008 Hello, In DVBViewer user can insert several recording folder but how can you make different recordings to go own folder ? for example I want my tv series to go folder TV_SERIES and movies to MOVIES folder. Quote
skb Posted December 14, 2008 Author Posted December 14, 2008 In the Timer window thanks alot.. still wonderin why epgplus does not make those recordings go to specific folder even it has the folder specified. is there file created which contains these recording information ? Quote
Gioxy Posted December 14, 2008 Posted December 14, 2008 is there file created which contains these recording information? You can check in a simpler way: EPGplus talk directly with DVBViewer, therefore after you program a recording in EPGplus you can check(and modify) all associated option in the DVBViewer Timer window... Quote
skb Posted December 15, 2008 Author Posted December 15, 2008 You can check in a simpler way: EPGplus talk directly with DVBViewer, therefore after you program a recording in EPGplus you can check(and modify) all associated option in the DVBViewer Timer window... I noticed this too. there seemed to be some problems with few epgplus settings. some of the recording was saved correctly to DVBViewer vcr. is there possibility change the saving folder from osd recorder ? Quote
Moses Posted December 16, 2008 Posted December 16, 2008 Nope, OSD can't change recording folders, yet. Quote
