Bigus Posted December 16, 2008 Share Posted December 16, 2008 Hi I've just installed the latest version of the recording service and enabled the web interface. I can't seem to get it to just show my favourites on the Programs Overview page (I use the mobile version). I've been into the service.xml file and tried adding UseFav 1 to the WebGeneral section and also tried creating an Input section like in the DVBViewer config itself but it doesn't work - ie: it still shows all available TV & Radio channels. If I turn off the recording service and use the regular HHTPServer.exe, with UseFav=1 in the .ini file, then it works. However I would really like to use the recording service for everything then I can log the workstation off etc. Any ideas? Thanks Bigus Quote Link to comment
Tjod Posted December 16, 2008 Share Posted December 16, 2008 The Recording Service did not support Favorites in the current version as far as i know. Quote Link to comment
Bigus Posted December 16, 2008 Author Share Posted December 16, 2008 The Recording Service did not support Favorites in the current version as far as i know. I see. Is it possible to use Apache web server to run the web interface for DVBViewer? Quote Link to comment
Tjod Posted December 16, 2008 Share Posted December 16, 2008 Web Interface 1.5 is a little web server on its own. You can not use it in Apache. But there is other solution DVBViewer Interface mit PHP. http://www.DVBViewer.info/forum/index.php?showtopic=28737 But DVBViewer and Apache have to run in the seam account to get this working. Quote Link to comment
Bigus Posted December 17, 2008 Author Share Posted December 17, 2008 Web Interface 1.5 is a little web server on its own. You can not use it in Apache. But there is other solution DVBViewer Interface mit PHP. http://www.DVBViewer.info/forum/index.php?showtopic=28737 But DVBViewer and Apache have to run in the seam account to get this working. Interesting. So that's a different interface, PHP based. It doesn't look like it has a mobile version. I think I'll stick with the recording service and hopefully it will be updated to include favourites at some point. I can't imagine it'd be a big job but then I don't know how or who develops it. Regards Bigus Quote Link to comment
brutus Posted March 24, 2009 Share Posted March 24, 2009 Why is it not possible to show only the favourite channels in the web interface ? I saw the option was even removed in the configuration window of the recording-service in one of the last beta versions. It would be much easier, if I now search on eurosport, I get too many eursport's, the same for tv-guide ... When will it be enabled again ? Quote Link to comment
Lars_MQ Posted March 24, 2009 Share Posted March 24, 2009 http://www.DVBViewer.info/forum/index.php?...st&p=224282 Quote Link to comment
brutus Posted March 24, 2009 Share Posted March 24, 2009 Hi Lars, thanks for your fast reply, do you suggest (by the link) to use the php version ? Regards Quote Link to comment
