Diego Posted December 17, 2008 Share Posted December 17, 2008 Well some time ago some of you talked about using ffdshow codec with DVBViewer. Then I remind that MPC decoder uses multithreading and also DXVA that should be a bless for many of us that doesn't have a new CPU. Some weeks ago I made some test using h264 ts recording with MPC HC and it worked with MPC decoder h264 and dxva. But unfortunately I' m not able to use the MPC decoder into DVBViewer even if the codec is showed (I obtain a black screen). So I thought at a workaround to make it working as seen in other dvb app. Why don't send the stream via http or udp to MPC and then using MPC directly as viewer? But till now I' m not able to use it. MPC always say me couldn't render the file and I tried many combination from Null render to VMR9 (windowed) or VMR9(renderless). But at the end I' m not sure something is really transmitted to MPC. I enabled unicast network and settled up server port and then used Open file in MPC with that address and port but always had problem with render. What to do? Any idea? Thank you for any help Quote Link to comment
Diego Posted December 17, 2008 Author Share Posted December 17, 2008 More or less resolved using netstreaming plugin Quote Link to comment
Diego Posted December 17, 2008 Author Share Posted December 17, 2008 More or less resolved using netstreaming plugin I said more or less because I' m able to see only SD channels but with HD channels I hear only the audio. I will do some more tests on next days. Quote Link to comment
Milly Posted December 19, 2008 Share Posted December 19, 2008 I said more or less because I' m able to see only SD channels but with HD channels I hear only the audio.I will do some more tests on next days. Try Corecodec i've tried everything and this is least intensive cpu wise and best reliability no-stutter solution Quote Link to comment
Diego Posted December 19, 2008 Author Share Posted December 19, 2008 Try Corecodec i've tried everything and this is least intensive cpu wise and best reliability no-stutter solution Milly thank you very much for the reply. Core codec are good but unfortunately does't use hardware acceretation of the graphic card. Another good codec that doesn't make hw accel is the divx h264 beta 3. Till now the only H264 codec I have that works with hw accel is the cyberlink (in overlay render mode). MPC decoder should be great because is free of charge. But I havn't understood why it play the recorded ts file but doesn't play the live tv. Quote Link to comment
Milly Posted December 20, 2008 Share Posted December 20, 2008 Try Corecodec i've tried everything and this is least intensive cpu wise and best reliability no-stutter solution Milly thank you very much for the reply. Core codec are good but unfortunately does't use hardware acceretation of the graphic card. Another good codec that doesn't make hw accel is the divx h264 beta 3. Till now the only H264 codec I have that works with hw accel is the cyberlink (in overlay render mode). MPC decoder should be great because is free of charge. But I havn't understood why it play the recorded ts file but doesn't play the live tv. Hiya mate, yeah i get you on the DXVA thing i've an ATI 3650HD which should enable DXVA - I've tried and failed to get anything to do it... As i said the corecodec is least cpu intensive option i've seen and quite frankly everything else is crap in comparison (powerDVD included) If you have any success with DXVA i'd be happy to hear your results... Quote Link to comment
ZappoB Posted December 20, 2008 Share Posted December 20, 2008 Could you please post a download link to the MPC codec, I would try it for my own. Quote Link to comment
kgw210 Posted December 20, 2008 Share Posted December 20, 2008 (edited) You'll find "fresh" SVN builds here: http://www.xvidvideo.ru/content/category/1/1/2/ Latest version with standalone Filters is SVN 929 Edited December 20, 2008 by kgw210 Quote Link to comment
Diego Posted December 20, 2008 Author Share Posted December 20, 2008 Could you please post a download link to the MPC codec, I would try it for my own. Well I downloaded from the opensource project Media Player Classic Home cinema. http://sourceforge.net/project/showfiles.php?group_id=170561 Just go in the stand alone filter section then search for the codec. After you downloaded you have to register codec and then use it under MPC HC. Quote Link to comment
