shadowdogg Posted December 23, 2008 Posted December 23, 2008 When I change it from MPEG2 to h264 as soon as i go onto that channel again it swaps itself back to MPEG2. Quote
Derrick Posted December 23, 2008 Posted December 23, 2008 Try a fresh channel scan on this transponder. Quote
shadowdogg Posted December 24, 2008 Author Posted December 24, 2008 Try a fresh channel scan on this transponder. Nope - doesn't seem to work. Still just does the same unless i do group B ? Don't know exactly what that means but i don't mind trying. to be fair - it doesn't look that bad as mpeg2 but im assuming h264 would make it look a bit better. Is there no way feature could automatically turn to h264 if resolution is HD? Quote
Derrick Posted December 24, 2008 Posted December 24, 2008 it doesn't look that bad as mpeg2 but im assuming h264 would make it look a bit better. ..if you can watch it and it's not h.264 you're obviously not watching BBC HD Quote
Lars_MQ Posted December 24, 2008 Posted December 24, 2008 it doesn't look that bad as mpeg2 but im assuming h264 would make it look a bit better You made my day. I assume you're the one taking a vw beetle and by putting a porsche sign on it expecting it to go over 300 km/h? It seems the DVBViewer knows a lot more about the DVB stuff than you, so just trust it and don't try the impossible... Quote
cpsumner Posted January 18, 2009 Posted January 18, 2009 Are you watching it over Virgin Media cable in the UK? If so, BBC HD is broadcast in MPEG2 on that platform, in fact all HD channels are. Quote
