dvbviewer problems
subdvbv
I have a motorised system but this presents me with the following
problems that I hope you can help me with
1. DVBViewer 4.0 does not display free to air Eurobird 9 "Hello HD" channels
eg HBO HD.
DVBViewer 3.9.40 however does with no problems. (I am using the same
HD codec’s in each instance - cyberlink 8 or arcsoft)
2. In a mulit-sat system Channellist search seems very basic. Putting "eurosport"
in the search field produces a dozen entries with no reference to which satellite
the results are applicable to. - highly frustrating.
Also there seems to be no way of searching just within specific satellites for specific channels
Am I using this wrong ?
3. Is there a simple "back" button that allows me to jump back, via a single click, to the
last but one channel viewed.
4. Is it possible to simultaneously connect two diseqc 1.2 motorised systems to DVBViewer?
If so how best is it done?
5.
DVBViewer is by far the best dvb software I have used. Thanks for your help.
ps I am using a Firedtv dvb-s2 card
asus p5n-e sli motherboard & a
nvidia geforce 7800GT with forceware 94.24 graphic card
Link to comment
