subdvbv Posted December 28, 2008 Share Posted December 28, 2008 I have a motorised system but this presents me with the following problems that I hope you can help me with 1. DVBViewer 4.0 does not display free to air Eurobird 9 "Hello HD" channels eg HBO HD. DVBViewer 3.9.40 however does with no problems. (I am using the same HD codec’s in each instance - cyberlink 8 or arcsoft) 2. In a mulit-sat system Channellist search seems very basic. Putting "eurosport" in the search field produces a dozen entries with no reference to which satellite the results are applicable to. - highly frustrating. Also there seems to be no way of searching just within specific satellites for specific channels Am I using this wrong ? 3. Is there a simple "back" button that allows me to jump back, via a single click, to the last but one channel viewed. 4. Is it possible to simultaneously connect two diseqc 1.2 motorised systems to DVBViewer? If so how best is it done? 5. DVBViewer is by far the best dvb software I have used. Thanks for your help. ps I am using a Firedtv dvb-s2 card asus p5n-e sli motherboard & a nvidia geforce 7800GT with forceware 94.24 graphic card support.zip Quote Link to comment
