wickham Posted January 2, 2009 Posted January 2, 2009 (edited) hi, i have: vista sp1 DVBViewer 4.0 skystar hd2 new transponders from kingofsat.net my problem is: i cannot find any dvb-s2 channels. i can find dvb-s HD channels but cannot any dvb-s2 channles. maybe I miss some settings. (is dvb-s2 device is: on) Can anyone any solution? thx, wh ps.: progdvb can find all (using same transponders and same dish position) Edited January 2, 2009 by wickham Quote
wickham Posted January 4, 2009 Author Posted January 4, 2009 Hi All! Please help me! I bought my DVBViewer 1-2 weeks ago. I have never heard about this problem before. Now I am asking this problem in other forums and receiving some reply about my scanning problem: And the answares were, that is a real problem and many users have problem with dvb-s2 channels. Does anyone know that? How can I solve this. I think it could be a problem for many users.. Hope it is solved. Please let me know... wh Quote
hdv Posted January 4, 2009 Posted January 4, 2009 Hello, which satellite you'll receive ? and have you tried switching "Stop Stream while tuning" and or "Direct tuning" ? Quote
Lars_MQ Posted January 4, 2009 Posted January 4, 2009 Use transedit from the members area and not some imported transponderlists, which may be missing half of the tuning parameters. Quote
wickham Posted January 5, 2009 Author Posted January 5, 2009 Hello, I tried: Eurobird 9 (9E) HelloHD pack (is free now) Cannot found any of them. Some are HD some only dvb-s2. I also tried: 23,5E ASTRA There is a pack which have dvb-s2 channels: Kabel D. Cannot find any channels which are using dvb-s2 I used new transponders from kingofsat. wh I didnt stop scnanning and also didnt try direct tunning. I will try. hope it helps.. Quote
wickham Posted January 5, 2009 Author Posted January 5, 2009 Hello, Ok. I will try transedit. (today someone from the another forum suggested this as well) Some others writing kingofsat .ini files not the best, offering: JoshyFun .ini files I choosed kingof sat because it looks up to date, dont know some parameters are missing or wrong.. I will try your ideas as well. Thanks for both of you! wickham Quote
hdv Posted January 5, 2009 Posted January 5, 2009 Hello, i had tryed JoshyFun.ini that don't work too. try the attached inis 00900235.zip but HelloHD is closed again Quote
wickham Posted January 6, 2009 Author Posted January 6, 2009 Thx for the ini files. Where does it coming from? It looks fine. HelloHD is closed. They were open just for 5 days.:-( thx wh Quote
