kobe8 Posted January 13, 2009 Posted January 13, 2009 Hi all! Dish movement does not work properly for my skystar hd2/motsat3: sometimes the dish moves on channel change and sometimes not. Probably this is not a new bug, but I don´t know if it has been considered for future dvb versions. In my opinion, this is the unique big problem for this application. Anyway, if I unselect and then select again the "shared lnb" in the hardware options menu and press Apply button, the dish works fine (and faster) always. My Options/Hardware configuration. Marked: Shared LNB has CI module Open whole transponder is dvb-s2 device retune on missing stream after 10 sec. I would like to thank you your work. DVBViewer is probably the best dvb program I´ve ever seen and the best solution for our HTPC´s. Thanks and regards, Sergio. Quote
Griga Posted January 13, 2009 Posted January 13, 2009 Please read this: http://www.DVBViewer.info/forum/index.php?showtopic=31406 Shared LNB Do you know what this option does? It's only suitable for *two* DVB-S devices that are both connected to a two-way-splitter, and the splitter to a single LNB resp. antenna cable. Anyway, if I unselect and then select again the "shared lnb" in the hardware options menu and press Apply button, the dish works fine (and faster) always. Which means, the device is re-initialized. Any other hardware option would have the same effect. Quote
kobe8 Posted January 14, 2009 Author Posted January 14, 2009 Please read this: http://www.DVBViewer.info/forum/index.php?showtopic=31406 Do you know what this option does? It's only suitable for *two* DVB-S devices that are both connected to a two-way-splitter, and the splitter to a single LNB resp. antenna cable. Which means, the device is re-initialized. Any other hardware option would have the same effect. It sounds good and reasonable, but I get the same result with Shared LNB option unselected. The only way (at least for me) to accurate always the correct dish movement on channel change involves to initalize the hardware options. Maybe drivers? I´m using the original skystar hd2 cd drivers and technisat web contains a newer version. I´m frightened about this option because DVBViewer works ok but the dish problem. Thanks and regards, Sergio. Quote
Griga Posted January 14, 2009 Posted January 14, 2009 Maybe drivers? Obviously. And obviously you didn't follow the link that I've posted above. So again: http://www.DVBViewer.info/forum/index.php?...st&p=228725 I don't post links just for fun. If you don't read what's written there you won't make it work. Quote
kobe8 Posted January 16, 2009 Author Posted January 16, 2009 Sorry, you are completely right. I have updated drivers and motor is working ok 100%. Great!! Tnaks and Regards. Obviously. And obviously you didn't follow the link that I've posted above. So again:http://www.DVBViewer.info/forum/index.php?...st&p=228725 I don't post links just for fun. If you don't read what's written there you won't make it work. Quote
