Skystar HD2 & Airstar 2 & EMP-Centauri P.168-W switch
wickham
Hi All,
I have a problem with using DVB-T and DVB-S card in DVBViewer with P.168-w swich.
This swich can merge antenna and sat singnal for one cabel after I have to separate them with diplexer and connect to the right card.
Unfortunately under DVBViewer I cannot wach dvb-t and dvb-s channels without freezing dvb-t. When connected both cabel to the cards dvb-t signal lose.
EMP-Centauri support saying this:
"you use the same software, but it controls 2 different pieces of hardware. There is good hope that if you would be able to switch one PC card off while you are using the other, the problem will disappear"
So when I wach dvb-t, skystar card should be off and when i change channels to dvb-s should be on again and vica versa.
Could it be possible?
Thx
wickham
Edited by wickham
