The One Posted February 5, 2009 Posted February 5, 2009 Just a thought.. Would it be possible to add a feature to save manual zooming on a per channel basis as some channels never actually fit perfectly. No matter what setting or configuration you are using. Quote
dyter Posted February 11, 2009 Posted February 11, 2009 I suggest Zoom default for TV (5% zoomed) and another aspect ratio default for video sush as divx (5% vertical streched) Quote
The One Posted February 14, 2009 Author Posted February 14, 2009 I suggest Zoom default for TV (5% zoomed) and another aspect ratio default for video sush as divx (5% vertical streched) Thanks for the reply. But I was thinking more along the lines of saving profiles for channels and file types for example. playing a divx I prefer to set my sharpness a little more and increase contrast a little. Or on a channel that has cinema wide screen open the zoom to remove the two black bars and apply my predeified contrast brightness and colour settings. selecting one button. basically selectable profiles for different channels and file types that define brightness contrast zoom settings. Quote
René Paw Christensen Posted September 16, 2009 Posted September 16, 2009 Great idea. I have a few channels that broadcast 16:9 content in 4:3 letterboxed, and on those channels I use zoom. Quote
